Old 12-08-2004, 08:48 AM   #18916
Sow&Steady's Avatar
Originally posted by Pyramid
Serpent racer - Face of the year 1st,
Is that you?
Handsome boyo he is ... the car I mean.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 12-08-2004, 08:49 AM   #18917
Sow&Steady's Avatar
Serpent Racer - Face of the year 2nd (runner up),
Ooops! Did he lose the race?
Old 12-08-2004, 08:50 AM   #18918
Sow&Steady's Avatar
Serpent Racer, Face of The Year 3rd,
This guy looks happy ... the Bingtang may have given headaches though!
Old 12-08-2004, 08:51 AM   #18919
Sow&Steady's Avatar
Originally posted by daniz24
Do you have authorization to post that "top secret" pictures?!?! Show us your picture please
Ooops, I smell copyright lawsuit coming ...
Old 12-08-2004, 08:51 AM   #18920
TitaniumR's Avatar
Hello to all here,
I finally replace the upper bumper with 3 racing's carbon version. My problem is that the droop grub screws goes thru a alu blk. How to secure the screw in position? Thread lock don't seem tight enough. Appreciate your advise. Thanks.
TitaniumR is offline   Reply With Quote
Old 12-08-2004, 08:55 AM   #18921
Sow&Steady's Avatar
Originally posted by TitaniumR
Hello to all here,
I used the blue threadlock which seems to work OK because when its dry it creates a kind of residue that holds the screw in place and yet you can still adjust.
If yours is too loose maybe try the teflon thread tape that plumbers use.
Old 12-08-2004, 10:32 AM   #18922
markp27's Avatar
Send a message via ICQ to markp27
Quick you are today, quick are you
markp27 is offline   Reply With Quote
Old 12-08-2004, 11:16 AM   #18923
Regional Moderator
daniz24's Avatar
Hmm, I prefer to call them Horny Face of The Year btw, where is Goldfinger??
daniz24 is offline   Reply With Quote
Old 12-08-2004, 06:29 PM   #18924
TitaniumR's Avatar
I did try with the blue thread lock. Will try your plumber's tape suggestion which I think should fix it for good. Thanks for your quick input!
Btw, can anyone comment on 710 plastic quality? my front upper arms now got a fair bit of play from pure wear and tear- caused by the king pin hole being enlarged as I checked it carefully. Visual checks, you can tell it's affecting the castor. The car has done about 1 gallon, no severe crashes or knocks. I just feel it's not the 950R plastic quality or maybe even the 705's.......
Other than this, it handles great!
Old 12-08-2004, 07:06 PM   #18925
InitialD's Avatar
Is it new? When I got it brand new, I was careful enough to thread it properly as the holes were kinda loose. It was easy to strip the thread if you forced the grub screws in slightly slanted.
Old 12-08-2004, 07:20 PM   #18926
TitaniumR's Avatar
Yes it's new. The thread is fine, grub screw is in straight. Just have to use plumber tape. What did you use to hold the grub screws in place? Thanks.
Old 12-08-2004, 07:21 PM   #18927
InitialD's Avatar
Are you sure you're not crashing a lot? We drive our cars almost every week and there's only minimal play. Definitely less play than that coming from the MTX-3.
Old 12-08-2004, 07:22 PM   #18928
InitialD's Avatar
I use blue threadlock. I also use a longer grub screw in place of the short ones that were given.
Old 12-08-2004, 07:35 PM   #18929
Pyramid's Avatar
Try this Goldfingers method, apply a bit more of thread lock to the grub screw, screwed it in and take it back out. Let the thread lock dry by itself on both parts then install the grub screw again.
Pyramid is offline   Reply With Quote
Old 12-08-2004, 07:41 PM   #18930
Pyramid's Avatar
There you go, the tallest guy. If you notice, always having a cigarrete either on his mouth (GQ cup) or hand (this pic)
