Old 02-05-2004, 01:13 AM   #3946
InitialD's Avatar
Originally posted by sparksy
The Yokomo also came with a solid front in their RTR kits.
You're right on that one. So does AE with the NTC3 which the shaft can be swap to the front or rear !
Old 02-05-2004, 01:42 AM   #3947
Originally posted by InitialD
I notice that on my local track which requires a fair bit of braking, I feel that I'm faster on the one way.
Anyway, what does using softer front tires do? More steering? Wouldn't that make the rear unstable?
More steering yes, must reduce the steering DR near 70%.
Rear unstable no.. when the rear of your car being unstable right after using softer front tires ( no other change)
- its time to lower the rear too
- too much steering lock (thanks Julius)
When using solid front, yes the car is very dead easy to drive (thanks again Julius) but when you check your lap times...
Just quick check for you D :
Can you drive your 710 with 35F and 35R with your current setup?
GoldFinger is offline   Reply With Quote
Old 02-05-2004, 01:45 AM   #3948
Originally posted by Sow&Steady
I think Goldfinger is one of Kok Heng's "students".
Who is he ? is he good ?
Old 02-05-2004, 01:48 AM   #3949
InitialD's Avatar
No. I have not had the chance yet ! Do you need to do that? Better / faster?
Old 02-05-2004, 01:50 AM   #3950
Default KHM
...Ops is he KokHengMeister..???
Old 02-05-2004, 02:00 AM   #3951
Sow&Steady's Avatar
Default Re: KHM
Not a bad guest!
Where do you live GoldFinger?
If I'm as old as the track in KL then this chappie is as old as ground its on!
Having said all that, he is one character you don't want to mess with on or off the track and yes, he IS faster than me despite bing much older
Sow&Steady is offline   Reply With Quote
Old 02-05-2004, 02:09 AM   #3952
InitialD's Avatar
Default Re: KHM
ROTFLMAO !
Old 02-05-2004, 02:16 AM   #3953
At first it is impossible to drive this 710 with that shore.
But when my setup is really dial up, it is not a problem anymore while using that shore. That is why Im gonna use that as my benchmark to dial up my setup too every track I race.
Better/faster? Not significant.. but easier to spot the setup problem.. like tire wear, camber adjusment.
Im using 37/37 or 40/40 now.
Old 02-05-2004, 02:18 AM   #3954
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: KHM
ROTFLMAO !
Now you know where your greasy paws have to go
markp27 is offline   Reply With Quote
Old 02-05-2004, 02:55 AM   #3955
Default Re: Re: KHM
Not a bad guest!
Down here, country with thousands island and problem either.
Sorry if im being so but i dont like that character either and I like the fact that he is faster than you..
Old 02-05-2004, 02:57 AM   #3956
Default yellow springs
Hi
Is there anyone who think that the rear yellow shock absorber springs are a bit too short?
They are shorter than the previous one coming with impulse or 705 Kit.
It is not a big problem, setting the ride height the collars go down until almost the end of thread
But when I check the tweak lifting the rear, the springs donít push the arms down to downstop. One wheel lift before the other because, probably, the suspension arms on this side move a bit less freely than the ones in the other side
The shocks length is ok, downstops setting is ok
Any tips?
Ciao
emynet is offline   Reply With Quote
Old 02-05-2004, 03:15 AM   #3957
cyba888's Avatar
The springs may seem short but once its installed onto your car it should be fine. Make sure both shocks are equal lenght.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-05-2004, 03:21 AM   #3958
InitialD's Avatar
Default Re: yellow springs
The yellow spring that comes with the 710 is fine. The yellow spring that came with the 705 is the one coming from Veteq. It is longer and softer as well than the stock shorter rear yellow springs that come with the Impulse Streetspec and the 710. Rene cornella mentioned that the longer rear yellow Veteq springs are equivalent to the short orange rear springs. The rule of thumb is that the Veteq rear springs are always 2 colors softer.
Are you checking the tweak with the rear sway bars on or off? Perhaps you need to check if the rear sway bar by itself can move freely without binding...
After you determine that the sway bar moves freely by itself, mount the sway bar on and check the tweak. If they tweak is off, adjust the rod length connecting the sway bar to the lower rear arm to suite the tweak.
Old 02-05-2004, 03:23 AM   #3959
InitialD's Avatar
Ok, I see. Thanks for the tip.
Old 02-05-2004, 03:32 AM   #3960
S710_Nut's Avatar
The only thing i do not like about this car so far is the e clip on the 2 speed. the cut in the shaft seems to be too narrow or the clip is not big enough
SN
S710_Nut is offline   Reply With Quote
