Serpent 710
Originally posted by Julius
Be carefull with those. They are from the 705. They have a thin peice between the thread and the ball, like the steel version. They snap in a crash....
http://www.mytsn.com/products/desc.asp?prid=2306
Originally posted by InitialD
Oh yes. Forgot about them. Are you referring to 808347?
Originally posted by markp27
Ok, thanks for the info - I thought the 705 used the same ones as the 710?
801219 Pivotball 8.5mm short
http://www.mytsn.com/products/product.asp?prid=2696
801222 Steeringblock FCset +alu balls 8.5mm
http://www.mytsn.com/products/desc.asp?prid=2771
I think the ones that were the same as the ones used on the 710 was suppose to be used with FC steering blocks on the 705...
Of course, yes - it was so long ago since I used the non-FC blocks that I'd forgotten about that.
A sure tell tale of someone who's too intoxicated by the power of the RING...
Can you find out what gearing and what tire diameters that they use on their current NTC3 and Mugen cars and what gearing and tire diameters that they used on the 710 previously? Like what MrChan mentioned, it could be due to those factors..
All of them where using Ellegi 40 F / 40 R
All of them where using 65mm front & 65mm rear from the box
Their gearing was different
JP FX was using 55 / 22 - 60 / 16
Sirio was using 56/22 – 60 / 16
The last one was using 56/22 – 60 / 17
Originally posted by Brett.w
And you guys are happy with it? (Speed and stuff)
Originally posted by jag
How about sharing some clutch secrets with us mortals?
Parts:
Yellow clutch shoe
1.8mm pre-tension spring.
Black clutch shoe cut up as the flyweights
Settings:
0.5mm clutch gap
0.2mm endplay
2.1mm pre-tension
Rene did all the tuning of the pre-tension by observing how my car performed - he can see and hear when it is correct. He does the same in tuning the engine.
I really can't say how to do this, I wouldn't be able to do it myself anywhere near as good as Rene and I couldn't really observe Rene doing the work, as I was on the driver stand.
Cheers, Mark.
judging by what happened at the weekend, I think I may well have mixed them up
