Old 04-05-2005, 06:42 AM   #20926
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by lagnaf
Thanks Mark,
You'r tha bomb
What clutch settings did you end up with eventually, it'd be interesting to compare what you had with mine.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 04-05-2005, 07:03 AM   #20927
jag
jag's Avatar
Originally posted by markp27
Actually my setup is virtually identical to that which Pyramid posted a week or two ago:
Parts:
Yellow clutch shoe
1.8mm pre-tension spring.
Black clutch shoe cut up as the flyweights
Settings:
0.5mm clutch gap
0.2mm endplay
2.1mm pre-tension
Rene did all the tuning of the pre-tension by observing how my car performed - he can see and hear when it is correct. He does the same in tuning the engine.
I really can't say how to do this, I wouldn't be able to do it myself anywhere near as good as Rene and I couldn't really observe Rene doing the work, as I was on the driver stand.
Cheers, Mark.
So you took a standard black clutch and cut it into 3rd's? Do you lay the pieces between the pegs? Is the 2.1mm pre-tension measured from the face of the nut (holding the spring) and the end of the clutch nut (holding the flywheel on)? Was the clutch real aggressive... snappy? Can you send your new "pit monkey" over to Ft. Meyers this weekend for my state race?
Thanks, jag
jag is offline   Reply With Quote
Old 04-05-2005, 09:03 AM   #20928
markp27's Avatar
Default Re: ZX-12 RACE Factory Settings
Mark,
would you be so kind and measure your carburator settings from Kirchenberg race in turns from closed ?
PLEASE
Well, it certainly seems that the LSN is run rich comparatively to the HSN. My settings are
4.5 Turns out on the HSN and 5.5 Turns out on the LSN.
Cheers, Mark.
Old 04-05-2005, 09:27 AM   #20929
markp27's Avatar
Thanks, jag
Here's a pic - it can explain it better than I can in words
I measure from the end of the flywheel retaining nut to the top of pre-tension nut with calipers in this manner:
The clutch was nice, it wasn't too agressive - probably you'd need to use a bigger clutch gap and/or grubscrews in the flyweights to achieve this.
My pit monkey is Sow&Steady - are you sure you want him or are you after the services of the one true Pit Prophet??
Old 04-05-2005, 09:48 AM   #20930
Pyramid's Avatar
Default Re: Re: ZX-12 RACE Factory Settings
Looks like it is the same available engine on shop shelves to me I would love to see one able to even start the engine at HSN 5.5 - LSN 2 ... no throttle apply
Pyramid is offline   Reply With Quote
Old 04-05-2005, 09:50 AM   #20931
markp27's Avatar
Default Re: Re: Re: ZX-12 RACE Factory Settings
Do you mean that when you get a new engine, the factory settings are the same as those I have now?
Old 04-05-2005, 10:04 AM   #20932
Pyramid's Avatar
Default Re: Re: Re: Re: ZX-12 RACE Factory Settings
I do not remember actually, but not as far as HSN5.5 LSN2. More like HSN4.5 LSN4.. Must check again on the upcoming shipment late this month.
Old 04-05-2005, 10:21 AM   #20933
markp27's Avatar
Default Re: Re: Re: Re: Re: ZX-12 RACE Factory Settings
Another reason why I should be updating the FAQ
Old 04-05-2005, 10:35 AM   #20934
lagnaf's Avatar
Send a message via MSN to lagnaf
Cheers, Mark.
I end up with this clutch setup
Parts:
Black clutch shoe
flyweight modification with 3 pcs M3x4mm setscrew
Settings:
0.4mm clutch gap
0.22mm endplay
1,35mm pre-tension
My carburator setings: LSN 2, HSN 6
lagnaf is offline   Reply With Quote
Old 04-05-2005, 11:05 AM   #20935
markp27's Avatar
Parts:
Black clutch shoe
Settings:
0.4mm clutch gap
0.22mm endplay
1,35mm pre-tension
Ow!!! Your carb needs resetting
Old 04-05-2005, 11:13 AM   #20936
Sow&Steady's Avatar
Originally posted by Brett.w
And you guys are happy with it? (Speed and stuff)
I've used it in two National races without problems. Especially in this last one where a lot of folks in the upper 40.9xx were having inteference issues.
Speed is faster than what my hands can do.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-05-2005, 11:25 AM   #20937
markp27's Avatar
And no thoughts of sending it for a software upgrade?
Do you have two receivers?
Old 04-05-2005, 11:27 AM   #20938
Sow&Steady's Avatar
Old 04-05-2005, 07:05 PM   #20939
JustRace's Avatar
Mark is truely a master. Anyone notice how he held the pinion and caliper but was still able to take the picture.
Initial...the only ring you'll have now is the one around the collar
JustRace is offline   Reply With Quote
Old 04-05-2005, 07:10 PM   #20940
Davo's Avatar
Default MOTORS FOR SERPENT
Hi
I have the following for sale!
Novamax S3 Modified Mossimo Fantini
(very reliable and still very tight)$200 ONO
JP Black NS12 S3 Box and Stickers Included!(run 1 meeting) $370
Full Serpent spring set $50 ONO
2x Glow plugs $15 (7 turbo!)size
MUST SELL MAKE OFFERS THANXZ!
Davo
XRAY
LRP
Much More
Davo is offline   Reply With Quote
