Serpent 710
Old 06-12-2005 | 02:35 AM
  #21661
markp27's Avatar
Originally Posted by buboy28
Mark: where did you buy those Serpent CVD's thanks
www.the-border.com
Cheers, Mark
markp27 is offline
  #21662
markp27's Avatar
Originally Posted by Julius
Some of our drivers indeed use the bearing oil. Putting a drop on the cvd's after a few runs, and cleaning at the end of the day (or before finals).
Ok, this is what I do too.
Cheers, Mark
markp27 is offline
Old 06-12-2005 | 02:41 AM
  #21663
buboy28's Avatar
Originally Posted by markp27
www.the-border.com
Cheers, Mark
ok, thank you very much
buboy28 is offline
Old 06-12-2005 | 05:43 AM
  #21664
Pyramid's Avatar
Registered User
Before I forgot again, if you experiencing rx cover slightly hitting the ground (when cornering) after installing the new lowered CG chassis, here is one example on how to do it,
Pyramid is offline
Old 06-13-2005 | 08:48 PM
  #21665
clmbia45's Avatar
Smile
Originally Posted by _cyclops_
What type of X-brace are you using.. i heard the plastic and the alu differ in size... so the chassis will bend if one of both is smaller...
There was considerable written about this early on. Perhaps Mark remembers where or put it in his Faqs. The plastic brace was made too short, by about 1 mm. To my knowledge this was never corrected by Serpent. However, the alloy x-brace is the correct size, and when installed on the new chassis, it does not bow the chassis when tightening the radio tray. Mine was dead flat and zero tweak after construction with the new chassis.
clmbia45 is offline
Old 06-14-2005 | 08:50 AM
  #21666
gfd2726's Avatar
Hi,
Can anyone tell me where can I purchase (online) ajustable aluminum shocks? Will the following shocks fit in a 710?
Mugen MTX3 ajustable aluminum shocks
Mongoose G4 ajustable aluminum shocks
R40 ajustable aluminum shocks
Thank you.
gfd2726 is offline
Old 06-14-2005 | 09:00 AM
  #21667
Pyramid's Avatar
Registered User
Serpent shock are different in between fr and rr lenght so I do not think you could find replacement. All those shock you listed wont fit. If you do not like what they are now for whatever reason, be patient, just wait for future release of their new dampers soon.
In the mean time, check out the following new additonal option parts,
SER-802173 Pully/shim 22T mid-side alu
SER-802345 Pully/shim 24T 2sp-center alu
SER-802393 diff-adjuster alu Pro + shoe
SER-802394 shoe diff-adjuster Pro
Pyramid is offline
Old 06-14-2005 | 09:24 AM
  #21668
Shop Owner
Default rc-toro coupon
To all the serpent fans,
Good news! Rc-toro is giving out 5% coupon for all car parts and car kits. To get the discount, please enter "5CARPK" while checkout. Thanks.
Toro_man
toro_man is offline
Old 06-14-2005 | 09:27 AM
  #21669
gfd2726's Avatar
Are there any adjustable aluminum damper shocks available now? Where can I get them? Thank you.
gfd2726 is offline
Old 06-14-2005 | 10:21 AM
  #21670
markp27's Avatar
Always first with the hot info - thanks, Pyramid!!!
markp27 is offline
Old 06-14-2005 | 01:24 PM
  #21671
border r/c's Avatar
Default The Diff adjuster alu Pro-set 802393
From the Source
at your Service !!
http://shop.the-border.nl/product.php?productid=22853
Serpent is pleased to present this beautifully machined aluminium Pro diff adjuster. Suitable for use on the front and rear of your Serpent 710, this part fits directly onto the standard differential, this orange anodised part allows for more consistent diff adjustment due to its stiffer construction.
The truly innovative part of this new adjuster set however, is the use of a diff shoe. Made from a PTFE material this diff shoe creates a much improved and smoother differential movement due to the material used. Also when the part wears you only need to replace the shoe.
Additional information:
Complete set comes with aluminum diff adjuster, shoe and adjuster screw.
Availability:
June 2005
border r/c is offline
Old 06-14-2005 | 07:39 PM
  #21672
Pyramid's Avatar
Registered User
How adjustable that you meant? The standard dampers already fully adjustable beyond any other maker doesn`t it? There is aluminum body for them as an options with the following part number,
SER-909410 Shock-body alu teflon front (2)
SER-909411 Shock-body alu teflon rear (2)
Pyramid is offline
Old 06-14-2005 | 07:49 PM
  #21673
Pyramid's Avatar
Registered User
No Bro.. you are the one who posted the hottest option of all time.. the new CG chassis
Pyramid is offline
Old 06-14-2005 | 11:25 PM
  #21674
wonder who comes first with the new shocks
_cyclops_ is offline
Old 06-14-2005 | 11:29 PM
  #21675
markp27's Avatar
Originally Posted by border r/c
From the Source
I think Michel is proving he has the one Ring
markp27 is offline
