Old 04-05-2005, 12:03 AM   #20896
InitialD's Avatar
Default Re: Horror pic!
Originally posted by markp27
Anyone looking for a second hand chassis?
Hey Bro Mark, I think you can still repair and use that chassis if only the front part where the bumper is bent. From the pic, I see that only the front part of the chassis is bent just before the front bulkhead.
Also, check on the receiver pack and perhaps the tank. On a bad crash like that, I would try to resoulder the receiver pack.
Old 04-05-2005, 12:06 AM   #20897
lagnaf's Avatar
Send a message via MSN to lagnaf
Originally posted by InitialD
Is your car a new car? Did you ever change the rear bottom arms? The new lower rear arms have about 2 mm longer plastic so that the pivot balls have more to thread. Less chances of the pivot ball stripping out. Else, you could use the longer steel pivot balls like the ones on 950R and 705.
This is what Paolo mentioned;
HSN: 5 1/2 turns
LSN: 2 turns
I have the S100003......Racing pack S710
Is this set including longer rear bottom arms
I will measure today!
Must change arms anyway
Great idea about the longer pivotballs
Thanks InitialD
lagnaf is offline   Reply With Quote
Old 04-05-2005, 12:08 AM   #20898
markp27's Avatar
Send a message via ICQ to markp27
I was thinking it would be re-useable, but there is actually a crack through the chassis, which you can't see on the picture No, I'm afraid I'll have to sell it on Ebay
I'll check the pack - I will be checking the tank, though - I was thinking the same as you.
Need to get a list of parts I need
markp27 is offline   Reply With Quote
Old 04-05-2005, 12:09 AM   #20899
InitialD's Avatar
I think this pack should already include those new lower rear arms.
I use the longer pivot balls including the newer arms. Bullet proof.
Old 04-05-2005, 12:10 AM   #20900
markp27's Avatar
Thanks InitialD
Something else, I do, is to place 1mm spacers on the wheel hexes, therefore, the pivotballs are screwed in 1mm further than normal on my car.
This also allows you to quickly tune the track width of your car, as you can very easily change a 1mm space for a 0.5mm spacer or even remove them. This allows for an instant 200mm->199mm->198mm change.
Cheers, Mark.
Old 04-05-2005, 12:11 AM   #20901
lagnaf's Avatar
Is this the result of broken cristal on straight in Kirchberg
Old 04-05-2005, 12:13 AM   #20902
revzalot's Avatar
I want a 710! Anyone know if Serpent's still selling the 710 with option parts in one kit awesome deal? Know of any other deals?
revzalot is offline   Reply With Quote
Old 04-05-2005, 12:13 AM   #20903
markp27's Avatar
Do you use the steel ones - I have some of the same material as the normal ones, but they are longer - don't know the part number anymore, though
Old 04-05-2005, 12:14 AM   #20904
markp27's Avatar
Default Re: Re: Horror pic!
Old 04-05-2005, 12:17 AM   #20905
lagnaf's Avatar
Here are some pics of race in Kirchberg.
And here
Old 04-05-2005, 12:22 AM   #20906
InitialD's Avatar
808346. These are steel ones and they are longer.
http://www.mytsn.com/products/product.asp?prid=411
Do you mean to say that you have the same aluminum ones but longer dimension?
Old 04-05-2005, 12:34 AM   #20907
markp27's Avatar
And here
Nice!!
Old 04-05-2005, 12:34 AM   #20908
markp27's Avatar
No idea when I got them
Old 04-05-2005, 12:48 AM   #20909
Julius's Avatar
Be carefull with those. They are from the 705. They have a thin peice between the thread and the ball, like the steel version. They snap in a crash....
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-05-2005, 01:04 AM   #20910
markp27's Avatar
Ok, thanks for the info - I thought the 705 used the same ones as the 710?
I think the ones I was using were destroyed in the crash
