Serpent 710
Originally posted by Julius
Let's see if I can direct link
Not like that ...
Not like that ...
p/s: Sorry for the shameless plug ! Crash, where is my Hara bodyshell paint scheme?
Originally posted by InitialD
Register on websites like www.3hobby.com and you'll have a private gallery. You can upload on those sites and then link pictures and they will show up like this...
Originally posted by 840918001
Hi Julius,
Could you tell us which hop-ups you run your car with?
Thanks in advance.
Thomas
Hi Julius,
Thanks in advance.
Thomas
-The long servo saver
-The new diff clamp
-2.5mm sway bar
-The alu mid axle bracket
-Lightweight pulley adapters
-Alu middle shaft
-ceramic thrust bearing clutch
The first three are the most important ones. Which make a difference regardless of ability.
The others make sense when you are able to run your laps within a few tenths of each other. Otherwise spend the money on tires and fuel for practice
I use:
-The new diff clamp
-2.5mm sway bar
-Alu middle shaft
I use:
-The new diff clamp
-2.5mm sway bar
-Alu middle shaft
Thomas
I guess for those who still get more wear in the rear would benefit as the split would stay the same almost throughout since the front tires will rotate more turns than the rear tires. More rotation in the front tires means more wear and this somehow will translate to even front and rear wear rate.
Front side of the car would get higher RC (corrected by Julius ) due to the front sitting lower because of smaller tires while maintaining same ride height.
And lastly, you get to use a bigger rear tire to achieve the required tire rollout / top speed for a particular track while still being able to use smaller tires in the front for better handling. Not forgetting the times when you need the tires to be big in the rear because of excessive wear and rear ride height clearance, you would still be able to use "smaller" front tires.
But our last conversation is overdrive vs handling.
Yes because of lower intertia (due to lower internal ratio), the car needs very little energy to get up to speed and little energy to stop also.
I think I mentioned this earlier...
Different inertia moment make a different result.
In order the turn the wheel in a surface, wheels need enough torque to overcome surface friction (its like inertia? no?)
Since the speed and diameter is different therefore torque carried by front and rear wheel is different.
That is the reason why I think in overdriven car, even using same rollout the front will role more than rear, since more torque (up to a certain engine rpm) is applied to front wheel.
I dont know about you Bro, but I start having a headache after reading my own post.
Not bad for a first time.
