Old 12-09-2004, 08:00 PM   #18946
InitialD's Avatar
Originally posted by Eddie
You mentioned updating the servo saver , what is the difference and is there an issue with the kit one ?
No issue with the stock kit one. But if your track is a flowing type with high speed sweepers, the newer and longer servo saver has less Ackerman and you'll have more corner speed with that on the car.
For me, I find that the newer servo saver also has a smaller turning radius which is good for smaller and tighter tracks that I run because for the same amount of turn on the Tx, you get more steering throw.
How does Serpent customer support compare to other brands ?
I would say that they are pretty good, if not amongst the best. In fact, the customer support coming from Serpent Holland is as good if not better.
We initially complained about certain parts of the car not being up to par and they responded by making harder and better parts a few months later in their running change. That's what I call service.
Old 12-09-2004, 09:42 PM   #18947
jas
jas's Avatar
Default Steering and throttle combo
Would the KO 2344 (0.13s) as a steering servo be "too slow" for the 710? I already have a 2343 (0.08s) but not sure if I should use hi-torque for steering and hi speed for throttle or the other way around? Or the milliseconds in difference really doesn't matter?
Thanks!
jas is offline   Reply With Quote
Old 12-09-2004, 10:19 PM   #18948
InitialD's Avatar
Default Re: Steering and throttle combo
Thanks!
Ummm, if PSI Racing was around, he'll definitely point you to the thread he asked Josh Cyrul about the same questions you're asking here. BTW, Josh Cyrul apparently uses 2344 on all of his gas cars (1/8th and 1/10th).
I guess it's personal preference... For me, the 2343 has more than enough torque for 1/8th scale steering servo much less for a 1/10th scale ! Some people cannot drive with a fast servo and slow analog servos are the only way for them. Some people like to get the fastest servo they can get on the steering.
But for throttle brake servo, I would go with high torque servos. And a lot of people will say that for throttle brake servo, go for analog type instead of digital. Less chances of a failure. I believe someone mentioned before that using too fast servos made engine tuning very difficult...
Old 12-10-2004, 12:19 AM   #18949
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Forgas State Race
Originally posted by impalabob64
Sup guys ,MARK ,D,my 710 brothern been busy ,how is everyone,got a state race this weekend ,i will be running a modified ns3 race, with the new powermax ,header an pipe combo,an will be trying out the rd logics cvds for the frt.The race will be held at the kissimee track, I raced there last month running frt an rear balldiff ,it worked perfect.So tell me whats new out there for our 710s.Oh i seen some rrr out there, they are really fast.
Hi impalabob64,
Long time no hear!
Well it is deepest winter over here in Germany, so the 710 has been mothballed for a couple of months now As for new bits - like D said above, the only real important ones for me are the new rear sway bars and the longer servo saver - nothing much else to consider.
I'll be getting myself the front diff, too - just in case I need it for the Winternats.
Actually, I got myself an RRR to test - I'm not going to be replacing the 710 with it, I just wanted to see what it was like. You can read my build write up here
Have fun at the race My racing is now limited to Virtual Racing.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 12-10-2004, 12:36 AM   #18950
InitialD's Avatar
Default Re: Re: Forgas State Race
So you're now "busy" on the PC huh? Gotcha !
Old 12-10-2004, 12:38 AM   #18951
markp27's Avatar
Default Re: Re: Re: Forgas State Race
Oops, giving me secrets away! Well, I would be busier on the PC if I had the Winternats track *cough* *cough*
Have you tried VRC with the USB thingy yet - it is amazing. I can see I will learn a lot about setup from this "toy"
Old 12-10-2004, 12:48 AM   #18952
InitialD's Avatar
Default Re: Re: Re: Re: Forgas State Race
Perhaps those guys are keeping it for themselves !
But I think with the changes that are currently ongoing with the Winternats track, it's pointless to offer it as nobody knows how the track is going to be...
I've downloaded it but not installed it yet ! Too busy with work... I'll get down to ordering one.
You see, on weekends, we have real RC cars to play with... With all the glory of the nitro fuel smoke and sound realism... <rub, rub>
Old 12-10-2004, 01:11 AM   #18953
markp27's Avatar
Default Re: Re: Re: Re: Re: Forgas State Race
You may very well think that, but I couldn't possibly comment
It will still be useful to get a feel for the layout and the driver stand position - I don't think the track layout has changed that much.
shame on you!!
You had to mention that didn't you
Old 12-10-2004, 02:41 AM   #18954
TitaniumR's Avatar
[/B]
I would think that this thread gives the best/fastest 710 support than to go thru mytsn! Thanks guys!
TitaniumR is offline   Reply With Quote
Old 12-10-2004, 03:22 AM   #18955
InitialD's Avatar
Ssshhh !
Hey, are you going to Thailand in January? What about MrChan? He's suppose to show us the ropes and bring us to the power power places...
Old 12-10-2004, 07:34 AM   #18956
crashed_1's Avatar
crashed_1 is offline   Reply With Quote
Old 12-10-2004, 07:44 AM   #18957
InitialD's Avatar
Originally posted by crashed_1
Wooi ! Don't pretend...
You can stay in the hotel room and isolate yourself if you want.
Old 12-10-2004, 07:52 AM   #18958
crashed_1's Avatar
Old 12-10-2004, 07:57 AM   #18959
InitialD's Avatar
Default Bali Open Race - Results
A Final - Result:
1 PETER WIDJAJA (Serpent 710) 173 Laps
2 FAYAKHUN TKI (V1RRR) 165 Laps
3 ALBERT (R40) 159 Laps
4 JEFFRY NINE BALL (Serpent 710) 159 Laps
5 ARIFIN TAN (Serpent 710) 151 Laps
6 SADIKIN A.C (V1RRR) 143 Laps
7 DONI AGUNG (FW05R) 140 Laps
8 EVAN SALU (MTX3) 140 Laps
9 RISMAN (Serpent 710) 133 Laps
10 HERI (Serpent 710) 120 Laps
http://www.mytsn.com/publ/publ.asp?pid=10815
Old 12-10-2004, 12:28 PM   #18960
Sow&Steady's Avatar
Default Re: Bali Open Race - Results
A Final - Result:
The usual suspects! Well done boys!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
