Old 10-25-2004, 12:31 AM   #18046
InitialD's Avatar
Originally posted by B4
I've been running the front diff for several races now and the only thing I need to do is tighten it up a bit more as I'm getting to much drive from the rear end. It's similar to being on rear drive only but no where near as bad. I have been putting up with this condition for a little while to try and sort out my suspension setup.
So B4, you've already solved that rear swinging out on power out of the corners?
Old 10-25-2004, 12:32 AM   #18047
InitialD's Avatar
Originally posted by markp27
Do I have to read everything you post
Do I need to remind you who has the RING this morning?
Old 10-25-2004, 12:36 AM   #18048
InitialD's Avatar
So what is the advantage of a tightly set front diff versus a solid?
Ummm, we need to get that beacon to signal Julius out of the cockpit !
I believe a tightly set diff will still diff out on power. It's a balance of both worlds. It allows you to off throttle better into corners.
Old 10-25-2004, 12:41 AM   #18049
B4
B4's Avatar
D,
I'll know for sure this weekend. But it was good enough as it is to give me 1,2,1,1 places in my last four races. I have the solid diff to put in if I can't cure this problem. I would think tyre wear might be an issue with the solid.
Mark you didn't mention tyre wear, is it the same as the oneway ?
B4 is offline   Reply With Quote
Old 10-25-2004, 12:44 AM   #18050
InitialD's Avatar
For me, I always want the front tires to wear at the same rate than the rears. Something which I cannot seem to get with a oneway or with a front ball without resorting to one grade softer tires in the front or using the new Ellegi tires all around.
Old 10-25-2004, 12:49 AM   #18051
Post Gear Diff
Hi ! I'm new to 710. Any one know that 710 Ball Diff change to Gear Diff, possible?
Looking forward to your reply.
Regards,
Calvin
calvinchan is offline   Reply With Quote
Old 10-25-2004, 12:50 AM   #18052
markp27's Avatar
Send a message via ICQ to markp27
Pardon me, my Lord, didn't want to appear rude
markp27 is offline   Reply With Quote
Old 10-25-2004, 12:51 AM   #18053
markp27's Avatar
Default Re: Gear Diff
Regards,
Calvin
There is no Gear diff available for the 710 - not sure if there would be an advantage to having a gear diff or not.
D, looks like you teritory
Old 10-25-2004, 12:54 AM   #18054
InitialD's Avatar
Default Re: Re: Gear Diff
Quick you are...
Old 10-25-2004, 12:58 AM   #18055
B4
B4's Avatar
Guys,
Could be time to create a Ring roster on 3hobby so all parties are aware of the scheduled ring bearer.
Old 10-25-2004, 12:59 AM   #18056
InitialD's Avatar
Calvin, Mark is correct. Only ball diff is available. Why do you need a gear diff when you need to mess around with the diff lube when you can tune the ball diff to infinite possibilities on the track without taking off the diff?
And no, the ball diff is pretty bullet proof. Not like some other cars where the diffs will wear out very fast. This is because the ball diffs on the 710 does not use pressure of the balls on the plates to set the diff tightness but rather rely on a plastic clamp system to set the diff tightness. I still have the same rear ball diffs and plates after close to 11 months of usage.
If you have any question, please do not be afraid to shoot.
Old 10-25-2004, 01:01 AM   #18057
InitialD's Avatar
Onkel Sow will definitely want to hog the RING as much as he can...
Old 10-25-2004, 01:02 AM   #18058
markp27's Avatar
Default Re: Re: Re: Gear Diff
Quick you are...
Not bad for an old man
Old 10-25-2004, 01:03 AM   #18059
markp27's Avatar
And D just takes the ring when he feels like it anyway
Old 10-25-2004, 01:05 AM   #18060
InitialD's Avatar
Yeah. There's been a power tussle with Onkel Sow and myself and as such that Mark comes in now and then to try and take advantage and swoosh it from us too.
