Serpent 710
Old 10-29-2004 | 03:20 AM
  #18211
JustRace's Avatar
Originally posted by Julius
Well this'll have to do for the moment.
Dutch team/treat at the euro's
I think pictures of the flag holder would be more interesting than the car
JustRace is offline
Old 10-29-2004 | 04:47 AM
  #18212
markp27's Avatar
I already did. But my pictures await the scrutiny of master censor Sow
There is a way young aprentice Create your own directories and then load your pictures into them - no censoring anymore
markp27 is offline
Old 10-29-2004 | 04:48 AM
  #18213
markp27's Avatar
I'm not much of a picture publisher but here goes.....
No KLM colours
markp27 is offline
Old 10-29-2004 | 05:19 AM
  #18214
jag's Avatar
jag
Default Re: Re: SWB
Originally posted by JustRace
jag...where do you race at?
I use a razor knife and just rock the arm while pressing down on the knife. It cuts real easily.
Also, if you're 2 seconds behind the fast guys the DRS isn't going to help. Since you said you're new then I would just concentrate on your driving. This is assuming your car is not having handling problems such as oversteering.
I am racing at Coral Springs right now and plan to go over to Go Racing and try that track also.
Don't misunderstand my question, I'm not looking for 2 seconds but what I am looking for is a starting point... should I be using DRS or not, should I use SWB, etc... I guess I will just try it and see what it does. I am sure it's me and not the car because there is another 710 there just like mine that is fast but the driver has a few years of experience.
jag is offline
  #18215
Ferdi's Avatar
Did Maarten Pothuizen created your body?
Ferdi
Ferdi is offline
Old 10-29-2004 | 05:28 AM
  #18216
Default Re: Re: Hop-ups
I use:
-The long servo saver
-The new diff clamp
-2.5mm sway bar
-The alu mid axle bracket
-Lightweight pulley adapters
-Alu middle shaft
-ceramic thrust bearing clutch
The first three are the most important ones. Which make a difference regardless of ability.
The others make sense when you are able to run your laps within a few tenths of each other. Otherwise spend the money on tires and fuel for practice
Isnt your car underweight with that setup or do you add weight to balance it better?
kreidel is offline
Old 10-29-2004 | 05:31 AM
  #18217
markp27's Avatar
Default Re: Re: Re: SWB
Hi Jag,
If I were you, I would take my time to become comfortable with the car. Get the car setup with the standard setup and remain with this until you feel you are comfortable that you know how the car is reacting around the circuit (i.e. where is it understeering, oversteering, etc.)
Only go as far as getting the ride hight and tyres right at first.
When you feel that the car isn't doing why you want it to do, try and limit your changes to the springs/damping + anti-roll bars. If you try to change too much at first, you will only get lost.
I've had the car a long time now and I learn more about the car all the time, there is a lot to discover, but the worst thing to do is to rush into it.
Don't start looking into DRS just yet, and only start with advanced mods like SWB when you really are fully comfortable with the car - otherwise you wouldn't really see the difference these items are making.
Go out there, drive and enjoy it at first.
Hope this helps, Mark.
markp27 is offline
  #18218
jag's Avatar
jag
Default Re: Re: SWB
Originally posted by InitialD
I used a sharp Xacto hobby knife. You need to get some spacers. The Serpent caster clips is perfect for this as it comes in 1 mm, 2 mm and 4 mm.
For more details, you could refer to Onkel Sow's article here.
Thanks, that's what I was looking for.
I do have a question that may seem obvious but I will ask anyway, if I move the bottom arm towards the rear 1mm then I need to move the upper arm back the same 1mm? I would accomplish this by reversing the top clips?
jag is offline
Old 10-29-2004 | 05:35 AM
  #18219
jag's Avatar
jag
Default Re: Re: Re: Re: SWB
Originally posted by markp27
Hi Jag,
Good point. I know the car is much better than the driver.
Thanks for the help.
jag is offline
Old 10-29-2004 | 06:08 AM
  #18220
markp27's Avatar
I use:
-The new diff clamp
-2.5mm sway bar
-Alu middle shaft
Julius, do you find that you ever have to switch back to the shorter servo saver at all?
Cheers, Mark.
markp27 is offline
Old 10-29-2004 | 06:10 AM
  #18221
markp27's Avatar
Default Re: Re: Re: Re: Re: SWB
BTW: I should have mentioned also, that it is also a good idea to get the camber of the tyres set correctly for your circuit. The front tyres should wear flat and the rears slightly coned.
Cheers, Mark.
markp27 is offline
Old 10-29-2004 | 06:37 AM
  #18222
Davo's Avatar
Default Serpent 710
hey, i have a serpent 710 and i race at lylidale it is a free flowing track and i lack a bit of speed. I am woundering if any1 could help me find a better gearing or have any idea as to how to get more top end out of the car. the straight at lylidale is around about 60 -70 meters if not longer. Could this be a gearing problem or is it just the way the car is?
Thanxz
Davo Serpent 710
KO PROPO
Nova MEGA! the only way to be! lolz
Davo is offline
Old 10-29-2004 | 07:39 AM
  #18223
Wap
Default Re: Re: Whats up
Hey Wap, welcome back.
BTW, I would suggest that you check the rear diff outdrives and the rear drive cups. Check to see if there is any kind of wear. You need to inspect closely in order to see it. If they are worned out, change them. That's probably the cause of the problem with the rear spinning out to one side.
thanks InitialD & Markp27, I look forward to racing again. The car is in a million pieces on the work bench and I will slowly put it together w/ the goodies that you suggested.
I hope to be racing in a week or 2.
wap
Wap is offline
Old 10-29-2004 | 09:37 AM
  #18224
jag's Avatar
jag
Default Re: Re: Re: Re: Re: Re: SWB
Cheers, Mark.
My fronts wear pretty flat. Are the rears supposed to cone in (shorter on the inside)?
How much toe-in do you run in the rear? I had a good racer tell me 2.5 to 3 degrees minimum is a must. Fact or fiction?
jag is offline
Old 10-29-2004 | 10:36 AM
  #18225
Julius's Avatar
No KLM colours
Too many people would make stupid jokes when I fly off the track....
Julius is offline
