Serpent 710
Originally posted by InitialD
Yeah. There's been a power tussle with Onkel Sow and myself and as such that Mark comes in now and then to try and take advantage and swoosh it from us too.
Originally posted by markp27
oh no, the dark lord has seen through my plan
Crashed_1 is a woozie. So he ALWAYS uses a front ball diff.
Well wozzies apart, crashes car is one of the most stable and FASTEST on the track !
I'm currently using it also with the 2.5 mm rear sway bar.
Originally posted by B4
Ah I see the ring is working then.
Also D sometimes "drops" a false ring - gets Sow and myself into lots of trouble when we try to use it
Very interesting - certainly from my experience of the solid, I would say my car was quicker on my track with the soild
Is the "it" a diff? If so, is it set tight?
The rear diff is set reasonably tight. Slightly tighter than I would with a oneway.
I was also using the thickest rear anti-roll bar, no front, red springs all round, front shock lain down and rears stood up.
I tried playing about with the diff tightness and I seemed to get even more steering on and off power (which doesn't really concur with the bible!?!?)
Yeah. Especially on your track, a car equipped with a JP FX engine and a good braking would be advantages. You can swoosh here and there very quickly with late braking.
No. "It" was referring to the solid front axle.
Is that the 3 mm roll bar you were using?
I may need to test out the rear diff and tighten them to see if my findings are the same as yours with the solid front.
Do you run a solid front or the diff, crashed? If so, how do they compare...better off power turn in and worse on power, with the diff?
Originally posted by crashed_1
One ways are a NO NO for me now...not on the kinda circuits we run on.
Woozie !
Woozie !
On the kind of tracks we run on, the choices are either the solid or diff....I've run the solid on several occasions and find them really nice, but I suffer off power steering badly on medium speed to high speed corners. On power is NICE though. Very stable and the car straightens out really quickly. The diffs are the ones I'm most comfortable with as they give me very nice and neutral handling on most of the corners we have on our local track. Unlike the solids, off power steering is very easily managed and clipping the apex is much easier...on power the car tends to slide out a little though, but i'm trying a stiffer rear roll bar setup which helps a little plus a very stiff front diff. One ways are a NO NO for me now...not on the kinda circuits we run on. I'm using Rene's PreWorlds setup on my car and i find it to be very neutral...which kinda suit my driving style at the moment...
I'd be interested if you would try stiffening the rear diiff, what difference it would make to off power steering - seemed to work for me.
Woozie !
Woozie !
Woozie !
Woozie !
