Old 01-23-2005, 10:11 PM   #19711
clmbia45's Avatar
Default Re: Re: Re: Re: Re: Starting to look better
Originally posted by InitialD
Mounting the bodyshell about 2 mm forward would give a little more steering according to Julius.
TNX!
clmbia45 is offline   Reply With Quote
Old 01-23-2005, 10:41 PM   #19712
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: In working progress.
Mark, trim the wheel wells bigger. You will definitely have problems during race with the wheels getting stuck under the bodyshell.
Really? - the wheels are full sized, I'll be using smaller ones for the winternats - you still think it is necessary?
markp27 is offline   Reply With Quote
Old 01-23-2005, 10:43 PM   #19713
markp27's Avatar
Default Re: Re: Re: Re: Starting to look better
You mean you're the ONE who replaced Rick V from the Border?
I would never suggest that I could replace Lord Rick!
Old 01-23-2005, 10:44 PM   #19714
TitaniumR's Avatar
Default Re: Re: fly wheel problem?
Why do you need to do that? The spring not tight enough?
On a side note, if you take out say a 0.2 mm shim behind the flywheel, make sure you add 0.2 mm shim in the front where the thrust bearing is to get back the same clutch gap.
The one piece mount and the stock engine mount is the same height. So it should not matter.
I think the problem is the alignment of the flywheel is not centered in the chassis hole where the flywheel is suppose to protrude out making it difficult for the flywheel to contact the starter wheel of the starter box.
Your comment on shim started me thinking. I removed it originally to be able to tighten further in without compressing the spring as much as if the shim was there. And I did not shim the trust bearing part. No wonder there was so much gap!!!
As I can see, the flywheel is parallel with the slot. I'm not sure about being centred. I now recall also the gear meshing is a little off meaning may not be parallel as I saw it. I'll check tonight. Thanks.
TitaniumR is offline   Reply With Quote
Old 01-23-2005, 10:48 PM   #19715
markp27's Avatar
Default Re: Re: extra body posts
Brett, after experiencing racing and all the things that can happen during that day, I've also started to mount these two body post protruding out towards the rear of the car on the rear shock tower.
Defense against unwanted rear attacks?
Old 01-23-2005, 10:49 PM   #19716
markp27's Avatar
Default Re: Re: Re: Check list
Originally posted by Pyramid
Be sure to check crankshaft pin (for conrod) before breaking in
Is there a known problem?
Old 01-23-2005, 10:58 PM   #19717
InitialD's Avatar
Default Re: Re: Re: extra body posts
Naaahhh... Just a precaution against a slightly incompetent pitman... Opphs <swoosh>...
Old 01-23-2005, 11:02 PM   #19718
InitialD's Avatar
Default Re: Re: Re: In working progress.
Tell you what... Get the scissors ready at the trackside. Run the car with the bodyshell and see if it interferes with the wheels...
Anyway, at least round the sharp lexan corners up...
Old 01-23-2005, 11:03 PM   #19719
InitialD's Avatar
That's a politically correct statement.
Old 01-23-2005, 11:04 PM   #19720
InitialD's Avatar
Default Re: Re: Re: fly wheel problem?
Old 01-23-2005, 11:08 PM   #19721
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
InitialD:
My nova Max is worn out. whats yer suggestion...get new P/S or get new engine? man this is direct.
*which budget wise worth it for a guy like me
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 01-23-2005, 11:14 PM   #19722
InitialD's Avatar
Originally posted by jfc_tech
InitialD:
I would just replace the piston sleeve if I know the following;
1. Bearings are in good working order. Not gritty.
2. Crankshaft crankpin is still good and a new conrod will still fit tightly around the crankpin.
But still if it was me and the bearings and crankshaft are already no good, I would still replace the piston sleeve and the necessary parts. With all of it changed, it is still half cheaper than going the new engine route... At the end of the day, it's your call.
Old 01-23-2005, 11:16 PM   #19723
markp27's Avatar
Default Re: Re: Re: Re: extra body posts
How many times do I have to tell you, D ..... pit monkey is the right name
Old 01-23-2005, 11:17 PM   #19724
markp27's Avatar
Default Re: Re: Re: Re: In working progress.
Me not finished Uncle D All will hopefully be relieved....ooops! revieled tonight
Old 01-23-2005, 11:18 PM   #19725
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Starting to look better
I think Michel has gone deaf *cough* *cough* tream *cough* driver *cough*
