Serpent 710
Old 05-17-2004 | 11:30 PM
  #10711
Motorman's Avatar
yes it was cold last weekend like 50 degrees. The only end I want to put them on is the front. Duh I suppose I could just put the titanium ones on from 3 racing. I'm using the 835 front axles in it already.
Motorman is offline
Old 05-17-2004 | 11:31 PM
  #10712
Motorman's Avatar
aw heck I'll just trim the stock serpent steel ones no biggie.
Motorman is offline
  #10713
markp27's Avatar
Originally posted by InitialD
I've hit a lot of stuff but I have not broken any pivot balls. Neither has any of the guys where we race locally. Perhaps it's the weather. Colder = brittle.
No, metal fatigue due to temperature occurs only at extreme temps - your body wouldn't like you to drive at those temps, so it is unlikely to be the cause.
markp27 is offline
Old 05-17-2004 | 11:33 PM
  #10714
Motorman's Avatar
the ball where it snapped off looks like it is a casting not a billet machining. the grain structure is coarse.
Motorman is offline
Old 05-17-2004 | 11:38 PM
  #10715
InitialD's Avatar
I would put the same steel pivot balls in the rear too. That's what the team drivers are doing at the current moment before better bottom rear arm plastics come out. Leave the length as stock. That's what you want... Longer pivot balls in the rear.
InitialD is offline
Old 05-17-2004 | 11:39 PM
  #10716
InitialD's Avatar
Then it's brittle !
InitialD is offline
Old 05-17-2004 | 11:40 PM
  #10717
InitialD's Avatar
You may be right ! I guess I'm mixing plastics with aluminum !
InitialD is offline
Old 05-17-2004 | 11:43 PM
  #10718
markp27's Avatar
Plastics are different, but plastic only becomes brittle at temp below approx. 0 Degrees C - but at higher temps they become more flexible and this may account for less breakages at moderate temps (i.e. above 25 Degrees).
markp27 is offline
Old 05-17-2004 | 11:44 PM
  #10719
Motorman's Avatar
I've heard the rear arm tends to break if you get hit moderatly hard from the rear. you guys experienced this?
Motorman is offline
Old 05-17-2004 | 11:46 PM
  #10720
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Charging batteries
Originally posted by Schrijver99
The Netherlands has also 230 volt
I'm going to keep my mouth shut in future
markp27 is offline
Old 05-17-2004 | 11:47 PM
  #10721
InitialD's Avatar
I've heard the rear arm tends to break if you get hit hard from the rear.
Have not broken that but what will tend to happen is the rear bottom pivot balls will strip the plastic threading from the arms. Hence a longer pivot ball (steel pivot balls) would benefit.
InitialD is offline
Old 05-17-2004 | 11:49 PM
  #10722
Motorman's Avatar
really
I'll have to keep that in mind. I did notice the plastic on the car is pretty soft and it does not take much torque to strip a hole out
Motorman is offline
Old 05-17-2004 | 11:51 PM
  #10723
InitialD's Avatar
really
A running change in terms of change of plastic quality from Serpent to update those lower bottom rear arms is on the way...
InitialD is offline
Old 05-18-2004 | 12:00 AM
  #10724
markp27's Avatar
really
What I do to try and prevent this is to set the width one millimeter shorter on both sides and then use 1mm wheel spacers to bring back the track width to 200mm - note if you are using a narrow rear width, then this isn't so necessary and it can limit the uptravel of the rear suspension.
markp27 is offline
Old 05-18-2004 | 12:13 AM
  #10725
Schrijver99's Avatar
CIf you got the FX engine, I would not know if they have the same internals having same dimensions as the Novarossi / NovaMega. Hope Schrijver99 or someone else can shed some light on this.
JP came out with their own line of FX engines but had Novarossi make them to their own specs. I know in the previous times, what JP does is get Novarossi engines and do their own "mods" on them and sign them off as modded JP engines.
The Crankcase is the same except for the "JP" on the side and the black coating.
The crankshaft is modded and coated.
Piston/sleeve is modded same as old RS an NS based JP's
And if you have the money: CERAMIC bearings
Found this in the JP FX Forum from daniz24 wich is super modded by JP himself:
Schrijver99 is offline
