Serpent 710
Old 05-16-2004 | 11:06 AM
  #10561
cox049's Avatar
Default Re: Strange problem with the Centax
Originally posted by markp27
Hi Guys, had a really strange problem with my centax today: both the metal shielded bearing were destroyed and I could hardly remove them from the bell and engine shaft I'm not sure why this occured as the thrust bearing is A1 condition - not signs of wear or damage
I checked the centax last night and it spun beautifuly - not notching or sticking.
At the track I didn't notice anything until I span the back wheels and felt something sticking - I thought at first it was the thrust bearing, but it was due to the destroyed metal shielded bearings.
The only thing I can think of was that an Mugen guy hit the side of my car quite hard, just after I blew him away but I don't see how this would have caused the two bearing to fail.
Any ideas anyone?
Mark, my guess is that the bearings failure isn't related to any bad adjustment/tuning of the centax. Sh*t just happens, Maybe one bearing was faulty and overloaded the other... you know... I don't think it will happen again with new bearings
cox049 is offline
Old 05-16-2004 | 11:15 AM
  #10562
markp27's Avatar
Default Re: Re: Strange problem with the Centax
I reckon you're right - still it was fun to show the two mugen drivers at the circuit where the speed is - they where having a careful look at the car afterwards
markp27 is offline
Old 05-16-2004 | 11:17 AM
  #10563
markp27's Avatar
Default Servicing metal shielded bearing.
Related to my bearing failure, does anyone know how to service metal shielded bearings.
Fortunately I have a couple of old centax shielded bearings which I can put in my 710, but one is quite gritty. I've cleaned it in degreaser and as I can't open the bearing, I've simply soaked it in serpent bearing oil. Seems nice and smooth now, but is there a better solution?
markp27 is offline
Old 05-16-2004 | 11:19 AM
  #10564
Schrijver99's Avatar
Default MACH 200m International
The final inscription date has been set to 30 May. So if you want to race at our Int. event come!
Schrijver99 is offline
Old 05-16-2004 | 11:25 AM
  #10565
Any ideas anyone?
Is your cluth-housing in its original shape, does it turn without a wobble?
Old 05-16-2004 | 11:27 AM
  #10566
Default Re: Servicing metal shielded bearing.
At the outer edge there is a very thin spring wich you have to take out in order to get the shield out. Also remember wich way the shield got out (Up/Down)
Old 05-16-2004 | 12:03 PM
  #10567
markp27's Avatar
Thanks for the tip - it turns freely without wobbling.
Cheers, Mark.
markp27 is offline
Old 05-16-2004 | 12:04 PM
  #10568
markp27's Avatar
Default Re: Re: Servicing metal shielded bearing.
Wow those things are tiny! any suggestions on how to remove the spring?
markp27 is offline
Old 05-16-2004 | 12:24 PM
  #10569
InitialD's Avatar
I painted this body yesterday. Nothing comparable to Glenn's and other guys hi quality work but I really enjoy doing it. And even more these days that I can't go to the track due to work...
cox049, you make awesome colour combinations. Another scheme to copy !
InitialD is offline
Old 05-16-2004 | 12:27 PM
  #10570
InitialD's Avatar
Originally posted by Pyramid
I find it hard to believe the dogbones could fly out if you set them at 200mm. It is already tight, or is the space different when using the front diff?
Using the front ball diff, the drive cups somehow are narrower. The front dogbones tend to come out more easily than with a oneway front.
Once I tought I lost it also but later find out that new impact bones are 'PoS'.
Ummm, really?
InitialD is offline
  #10571
markp27's Avatar
Hey, last time you were going to copy Kevin's scheme....
markp27 is offline
Old 05-16-2004 | 12:28 PM
  #10572
InitialD's Avatar
Default Re: Re: ?
If you need to know what's good or bad about S710, browse as many pages back to read what they all have to say.
The FAQ ! Seek the FAQ keeper and you'll find the light !
I believe the Serpent needs to be built and set correct. Once that is done, driving the 710 should be pretty much easy.
InitialD is offline
Old 05-16-2004 | 12:31 PM
  #10573
InitialD's Avatar
Precisely ! Made even worse when you're spoilt for choices with so many nice ones to copy and with people like crashed_1 as your wingman...
InitialD is offline
Old 05-16-2004 | 12:32 PM
  #10574
InitialD's Avatar
Default Re: Re: Re: McLaren F1 GTR Longtail
Originally posted by GlennCauley
I am going to save this for our Canadian Gas Nationals in August and run it there... I believe they have a concours event.
I may be wrong but most of the time, I believe the concours event would make it compulsory to use only bodyshells that you're gonna use for racing... I may be wrong.
InitialD is offline
  #10575
InitialD's Avatar
Default Re: Re: ?
Originally posted by Wap
But if you are like me i would buy the best car anyway (710) and learn as i go
I started that way. Driving the Serpent somehow made it possible for me to understand and aquire as much knowledge about RC cars. That's one of the best parts I like about RC besides driving and building the kit ! That of course does NOT include painting !
InitialD is offline
