Old 05-16-2004, 08:25 PM   #10591
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Need some setups
Originally posted by Marcos.S710
thanks for the set up "D"
Hey Marcos, did you try it out?
Old 05-16-2004, 08:30 PM   #10592
Default Re: Re: Charging batteries
Originally posted by InitialD
I would charge the receiver anywhere from 0.5 to 0.8 Amps. Max would be 1 Amp as they are AAA type cells. For the glow plug cells, I would charge it at 1 to 2 Amps as they are C type cells. Make sure the Apexi charger is able to charge 1 cell as the glow plug ignitor consist of 1 cell only. Not many chargers can charge a single cell. For the Tx pack if you have (AA cells), I would also do about 1 Amp for charging.
Thanks 'D' yep it can charge 1 .... 10 Ni-Cd / Ni-MH Cells
Brett.w is offline   Reply With Quote
Old 05-16-2004, 08:31 PM   #10593
InitialD's Avatar
Originally posted by SupermaxxRich
So any tips "D" on keeping the dog bones in place when running the front diff? I'd really appreciate some help, thanks....
Try running a slightly narower front trackwidth like 199 mm or 198 mm. Try not to set the EPA of the steering servo to lock a lot at the end of the steering movement. Lastly, you could cut very small pieces of fuel tubing and insert it in the outdrive of the front ball diff to push the dogbones towards the drivecups. Make sure that upon suspension compression, the dogbones still have slight lateral play to avoid binding.
Old 05-16-2004, 08:36 PM   #10594
InitialD's Avatar
Default Re: Re: Re: Charging batteries
Cool. Does it use DC current? Make sure you get DC power supply unit that can supply clean direct current. I have a 14V / 10 Amps. Gives ample power for my KO BX213MH charger especially if I'm charging my 9 x AA Sanyo 2100 mAH Tx pack.
If you are very familiar around electronics, you could even get DC power supply cheaply. Think computer PS unit ! They provide very good and clean DC supplies and they come very cheap too.
Old 05-16-2004, 08:47 PM   #10595
InitialD's Avatar
Default Re: Re: Re: Re: Servicing metal shielded bearing.
Originally posted by cox049
Mark, those bearings take huge high RPM's so keep the oil as thin as possible
True but I don't think you need those bearings to be as smooth as possible. If you're talking about other places, then I would agree. Imagine, how much HP do you gain from making those 2 tiny small bearings smoother? I would not do it at the expense of reliability. That's just me. Although thin oil makes for smoother bearing, you need to maintain them very regularly. And I personally dislike the bearing oil splattering in the clutch bell making the clutch slip...
Old 05-16-2004, 08:55 PM   #10596
SupermaxxRich's Avatar
where can I get those GQ wheels from at good price?
SupermaxxRich is offline   Reply With Quote
Old 05-16-2004, 09:02 PM   #10597
InitialD's Avatar
Where are you at?
Old 05-16-2004, 09:09 PM   #10598
Vancouver, BC, Canada
Old 05-16-2004, 09:28 PM   #10599
Pyramid's Avatar
Ummm, really?
Big time!!
Pyramid is offline   Reply With Quote
Old 05-16-2004, 09:31 PM   #10600
Pyramid's Avatar
http://www.gqproduct.com/distributors.htm
Just click on email, I believe the dist info still not available online.
Old 05-16-2004, 09:38 PM   #10601
Pyramid's Avatar
Originally posted by roadrage
InitialD no i dont drive 1 but i wish,is there sum1 my age that does?
I believe it is in Thailand which 1/8 actually being the only car he`s been driving. You seen him D on Asia Challenge?
Old 05-16-2004, 09:38 PM   #10602
what are the prices for those wheels? That website doesn't tell you much?
Old 05-16-2004, 09:43 PM   #10603
rwisejr's Avatar
Send a message via AIM to rwisejr
http://shop.radiostyrt.no/index.php/...079667bb3b5bac I buy stuff from him all the time very fast shipping of products
rwisejr is offline   Reply With Quote
Old 05-16-2004, 09:53 PM   #10604
Pyramid's Avatar
http://www.daltonshop.com/gqproducts.htm
For your reff only, 1USD=Rp9000 at this moment. So those RETAIL price divided by 9000 is equal to USD.
Old 05-16-2004, 10:02 PM   #10605
Thanks for the link rwisejr, I'm going to get some from there. I noticed they only have the 42 and 45 shore tires?? Is that all they carry or are they just out of stock on the 40 shore tires??
