Serpent 710
Old 05-18-2004 | 12:37 AM
  #10726
PSI Racing's Avatar
Dang, I just went to Vegas for the weekend.
Now I have to read 8 pages to catch up.
PSI Racing is offline
Old 05-18-2004 | 01:20 AM
  #10727
Sow&Steady's Avatar
Hope you win big there!
Or was there a race? Did you take some pictures?
Sow&Steady is offline
Old 05-18-2004 | 01:22 AM
  #10728
Sow&Steady's Avatar
Originally posted by Schrijver99
The Crankcase is the same except for the "JP" on the side and the black coating.
The crankshaft is modded and coated.
Piston/sleeve is modded same as old RS an NS based JP's
And if you have the money: CERAMIC bearings
Found this in the JP FX Forum from daniz24 wich is super modded by JP himself:
Super-modded how? Deeper grooves?
I noticed that there isn't a mid-range needle adjustment .. this is the 3-port right?
A 5-port one is also available at rc-mushroom.
Old 05-18-2004 | 01:25 AM
  #10729
PSI Racing's Avatar
No.
I took my wife there for her birthday.
I didn't gamble too much.
  #10730
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Charging batteries
Originally posted by markp27
I'm going to keep my mouth shut in future
Aww ... don't do that man! It'll be boring in here.
Old 05-18-2004 | 01:26 AM
  #10731
Sow&Steady's Avatar
No.
Aha! The question is did she gamble? One can do quite a lot and get away with it on one's birthday.
Old 05-18-2004 | 01:30 AM
  #10732
PSI Racing's Avatar
Yeah she went gambling.
I spent most of my time drinking.
Old 05-18-2004 | 01:32 AM
  #10733
Schrijver99's Avatar
The ports are of a different shape opening (see another pic from daniz24 at the bottom)
Yes it's a 3-port FX (shame it's not mine i've a normal modded FX)
And sorry but the P5T at Mushroom is an old .21 buggy engine
Schrijver99 is offline
Old 05-18-2004 | 04:13 AM
  #10734
PSI Racing's Avatar
Have you guys seen this yet?
http://www.mytsn.com/products/desc.asp?prid=3706
Old 05-18-2004 | 04:16 AM
  #10735
InitialD's Avatar
Yup. Read about it and was aware that Serpent was going to come out with it. Unless you really run on a high bite track, I don't see anyone using it.
InitialD is offline
Old 05-18-2004 | 04:31 AM
  #10736
buboy28's Avatar
serpent option parts
guys, any news if serpent is going to come up with any universal swingshaft or an aluminum threaded body shocks i am considering the 3racing hop-ups but having second thoughts thanks........................
buboy28 is offline
Old 05-18-2004 | 04:36 AM
  #10737
PSI Racing's Avatar
Default Re: serpent option parts
Serpent has aluminum threaded shocks.
The fronts are 909410
The rears are 909411
Old 05-18-2004 | 04:43 AM
  #10738
buboy28's Avatar
Default Re: Re: serpent option parts
ok thanks, will change my 710 plastic shocks to an aluminum one
buboy28 is offline
Old 05-18-2004 | 05:08 AM
  #10739
rcpanama's Avatar
Smile Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Need some setups
Originally posted by InitialD
Cool ! I guess you found the lottery ticket ! Gearing and clutch setup plays a lot of importance. Glad it worked well for you.
Yes I did
Did I hear gays right?
Sorry big mistake Drivers
Jose, pretty impressive stuff with ceramic bearings and all ! That's about what I got in my car as well except for the ventilated disc (mine is 9606). I do not have the wheel axles and dogbones as yours and of course, my bearings are just the stock rubber sealed Serpent ones.
I have also the ceramic bearings in the front and rear Diff
Anyway, I would not use the shock seal shim. I believe that only helped when the rubber membrane was off different design. Since the running changes they made to it, I was told that the shim was no longer needed. Just thought I should mention it.
Yes you are right, I had to cut the membranes on the side so they could fit, shock shim crated a bubble inside the cylinder, it works OK as of now, will check without them next time.
This is my Serpent
rcpanama is offline
Old 05-18-2004 | 05:11 AM
  #10740
rcpanama's Avatar
Smile
Final Picture
rcpanama is offline
