Serpent 710
Old 05-09-2004 | 07:42 PM
  #9976
InitialD's Avatar
Originally posted by cox049
I'm going to try it D and I'll report.
Cool.
Another for you D : I mounted the rear diff with Super Grease, all ok at the track but when the diff cools down (couple of hours after use) it gets really hard to move. I blew it with hair drier to get it to OP temp and it got soft and nice again. Does this happen to you or maybe I did something wrong?
I don't think it's a grease problem. I believe it's the nature of the ball diff itself. Check Julius' ball diff article. The diffs need to "warm up" first before the settings "settle in".
InitialD is offline
Old 05-09-2004 | 07:43 PM
  #9977
InitialD's Avatar
I had a revelation today brothas and sistas You have to master the clutch if you wanna succed in RC
I was (and still am) a believer that motor power isn't everything. Clutch setup will make up for the seemingly lack of power.
InitialD is offline
Old 05-09-2004 | 07:47 PM
  #9978
Motorman's Avatar
D it fits in the stock nut its just a tight fit. you can always sand the outside a squeek on a belt sander or with a dremel if its to tight for your liking. however without an agerssive clutch shoe its kinda a moot point. as you wont like it on a stock shoe.
Don't know if it is necessary or if it would work. If somebody wanted to try, then the set screw needs to be mounted in the MIDDLE of the flyweight to balance it out when you mount the flyweight in the middle of the pins. Something to think and try.
does not matter where you put the set screws in the weights as long as there all in the same place on each shoe it will balance. the closer to the tips the more centrifical force they create.
UNLESS
your not using the shoes in a swing condition (you have cut them to slide between the pins) then they need to be in the center or they will get crooked as they come out.
Motorman is offline
Old 05-09-2004 | 08:09 PM
  #9979
InitialD's Avatar
Originally posted by Profoxcg
by using a larger 2nd speed pinion then i should be good, correct?
Yup. But you should go with the smallest 2nd gear pinion (21T) and biggest 2nd gear spur (57T) to get close to stock Mugen 2nd gear ratio (5.09 versus 5.42). If the Mugen uses 62 mm tires and 5.42 FDR, then you should use 58 mm tires with 5.09 FDR (21/57) to match their tire rollout.
InitialD is offline
Old 05-09-2004 | 08:11 PM
  #9980
InitialD's Avatar
Agreed and understood.
UNLESS
That was what I meant...
InitialD is offline
Old 05-09-2004 | 08:36 PM
  #9981
Default just double checking
the higher the number the more accel but less top end correct? and visaversa, less of a number more top end less torque/ accel
Profoxcg is offline
Old 05-09-2004 | 09:03 PM
  #9982
Motorman's Avatar
I figured so.
anyone having trouble with first gear pinions wearing excessivly??
anyone interested in titanium pinions.
Motorman is offline
  #9983
InitialD's Avatar
Default Re: just double checking
But as with all things, there is a limit to everything.
InitialD is offline
Old 05-09-2004 | 09:09 PM
  #9984
InitialD's Avatar
Use less powerful engines or send us your engines !
But seriously, I found no trouble. I think they are much better than the other cars.
I know a guy who would ! (j/k) But hey, wouldn't titanium be a lousier metal for abrasion?
InitialD is offline
Old 05-09-2004 | 09:31 PM
  #9985
Picard's Avatar
Thanks for the feedback on the tyres guys.
I am trying GQ's and Stao's on the snake this weekend
Picard is offline
Old 05-10-2004 | 12:27 AM
  #9986
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Originally posted by GoldFinger
Please refer the manual, step 3.1 :
The G22 bolt is too tall.
Sorry for the late reply.
Yes, I've already changed the bolt to a shorter one because I prefer the allen type head.
So the E12 bolt (the 2pcs in front) on the step 3.3 cannot keep the upper diff cover in tight condition, the 2 bolt hitting each other(G22 vs E12).
Actually did not have the problem when I was using the original G22 bolts.
Pls check the diff assembly (mounted in the car) if you can move the diff up and down a bit, most likely you have this problem. Worn out U13 bearing could make that condition also.
I've checked the U13 bearing. They are like new. The rear diff is secured and cannot movbe up and down.
Worn outdrive only make it worse.
Lower the G22 bolt 1mm, .5mm should enough.
Replace 802305 + 802306, or use the old one but find a M3x0.5
Hand Tap, re-thread the hole.
The problem will gone !
Like I mentioned above, I used a shorter allen type M4 screw to replace the G22. I don't think that is the one causing the problem. I think it's the rear diff outdrive cups causing the problem. I've grinded the dimples to make it smooth and the rear does not "jump" or the bodyshell vibrate when I apply throttle on the starter box or on the track.
This solution is find by Pyramid, he is a happy man today.
Watchout D he is Nats no.3 now !! and he can proove his 710 is the fastest in 1st Nats yesterday.
All the way ! Good luck to him.
Ooopss, there is 1 thing I forgot, he is pursuing the TQ is only because the Trophy is good
InitialD is offline
Old 05-10-2004 | 01:12 AM
  #9987
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
Im really jealus with you.
At this working hour, you still manage a time to check your car....
I supposed you were a big investor then..
Since you were an investor, do you heard an issue that our "mothership" is have financial problem ? is it true ?
I hope it is not.
GoldFinger is offline
Old 05-10-2004 | 01:23 AM
  #9988
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
I wish I was ! No, don't be jealous ! I did not check my car. Those were the things I remembered when I checked my car on Sunday morning. Of course the minor details as to what I did to my car I know by hard already...
I hope it is not.
Mothership problem after Mother's day? No, I am not aware of it.
InitialD is offline
Old 05-10-2004 | 01:33 AM
  #9989
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
I forgot that i was talking with one of the serpent die hard.
(Thank you for the jealous correction )
Old 05-10-2004 | 01:42 AM
  #9990
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thrustbearing after run.
It takes one to know the other...
InitialD is offline
