Serpent 710
Old 12-15-2003 | 06:57 AM
  #1666
Julius's Avatar
Originally posted by Thaasman
Yeah if i had one allready, can't afford one now i bought the 710
I hope julius can give me some answers about the reciever protector..
I'm using the one that comes with the futuba 3vc
you can see it in one of the pictures too..
My first reaction is the receiver is the wron way around.
The wires (connectors) should point inward. There is space between the throttle servo and the receiver to put excess wire etc.
Julius is offline
Old 12-15-2003 | 08:41 AM
  #1667
Rene C.'s Avatar
but i have i MICRO reciever...
How small must it be
Hi Thaasman !
You are not alone. I got some e-mails about the placement of the receiver.
So I made a photo of my radioplate. The plugs and the crystal should look to the inside of the car. The wires you can lay down between the tank and the servo. On my radioplate I have an extra short cable for the pers. transponder. I use no switch. My connection plug to the battery is mounted on the top of the steering servo.
The problem with the receiver you use is, that the plug’s and the crystal are not on the same place. I don’t think you can put the receiver like I did. For sure you have tried that. Sorry, bud a cover will not fit with your receiver.
Rene C. is offline
Old 12-15-2003 | 09:01 AM
  #1668
dtm's Avatar
dtm
Default Flexi Shock Mount/Rear Gearbox cover
I looked at 2 710 tonite....is it me...or is it part of the design feature that the top of the rear gearbox flexes when you twist the rear shock tower (not using too much force neither).
Are we looking at another HPI Pro 3 flexibe design???? I almost parted with my money until I saw this.......
dtm is offline
Old 12-15-2003 | 09:12 AM
  #1669
fmolzer's Avatar
Default Rx mount
Dang,
and I just bought 2 new futaba PCM Rx:s tfor my 710 to be, looks like they will not fit.... First person to come up with a mod that fits the Rx AND offers protection from side impacts, please post here.
fmolzer is offline
Old 12-15-2003 | 09:17 AM
  #1670
Thaasman's Avatar
Post
Originally posted by Rene C.
Hi Thaasman !
Yup that's the problem, if the crystal and the connectors are on the same side there would be no problem, and cutting on the cover will not fix it either because there is still the throtle servo
But thanks for the reply and the pics
Thaasman is offline
Old 12-15-2003 | 09:22 AM
  #1671
Thaasman's Avatar
Default Re: Rx mount
Originally posted by fmolzer
Dang,
It seems to be that you can only use the protector if you'r crystal and wires are all on the same side....
Thaasman is offline
Old 12-15-2003 | 09:24 AM
  #1672
Thaasman's Avatar
Default Re: Flexi Shock Mount/Rear Gearbox cover
Can you be a bit more clear on this, because i don't understand that well
Thaasman is offline
Old 12-15-2003 | 09:36 AM
  #1673
InitialD's Avatar
Hey Rene, you have your own car and Julius doesn't?
InitialD is offline
Old 12-15-2003 | 09:39 AM
  #1674
Thaasman's Avatar
Post
Now the thing is: at my impulse(and i think with the 705 too) the reciever is mounted between the tank and the exaust..
So it was always "protected"
Now with the 710 the reciever is mounted on the otherside and if you have a reciever like me and you can't use the protector it isn't protected at all! And i mean really NOT at all.
So it's a pretty scary tought if you have a side impact...
See what i mean....................................
Thaasman is offline
Old 12-15-2003 | 09:40 AM
  #1675
InitialD's Avatar
Dang,
If what Thaasman says it's true that the protector can only be used if the crystal and wires are all on the same side, then the 3PK PCM and HRS receivers should be OK...
Just checked my receivers and indeed that the wires and the crystals are on the same side. I guess I have to get my own 710 to find out !
InitialD is offline
Old 12-15-2003 | 09:43 AM
  #1676
Julius's Avatar
I guess you hold the chassis down and with the other hand tried to pull the shock tower backward or twist it.
That force is never on the shock tower. What you are doing does not happen during driving so it is not an issue.
I have never seen the HPI car you mention so I don't know what the problem with that car is.
Julius is offline
  #1677
Thaasman's Avatar
Thanks for the reply julius, but like rene said, my reciever has the crystal and the wires not at the same side so there will always be one of them in the way
Thaasman is offline
Old 12-15-2003 | 09:45 AM
  #1678
InitialD's Avatar
In certain ways, I like the 705 receive replacement better. A good balance of accessibility and protection. The Impulse PRO receiver placement was good but it was difficult to access the crystal. Not to mention certain people had problems with glitches due to the placement of the receiver.
My opinion? I don't like the placement of the receiver on the 710. Just like I do not like the placement of the receiver on the MTX-3 and V1RR EVO. My 2 cents.
InitialD is offline
Old 12-15-2003 | 09:47 AM
  #1679
tranced's Avatar
Something like this?
awesome!!
now, is there any possibility you would be able to explain how this active toe-in works?
tranced is offline
  #1680
Julius's Avatar
You might try making a slot where the crystal fits through so you can mount it with the wires to the inside of the car?
Julius is offline
