Like Tree3Likes
Mugen MBX6
Old 12-30-2011, 10:20 AM
  #14716
A newbie question. How to properly set the camber, caster and toe on the car? I always used to run at factory setting never venturing into the setup.
I like to experiment with the setup. I have read enough on what the setups mean and how they can change the handling. I just need to know how to change them on the Mugens.
Our track is very loose, slippery and dusty. This is what I have already done:
1. I figured out the rear toe and anti squat by swapping the rear plate. I use 0 and 3 rear toe plate.
2. I also removed anti-roll bars as I read they are most required on high tractions tracks
3. Changed to light diff setup - 3-5-3
4. Removed the wheelbase spacers for shortest setup, since our track is small and tight compared to US style tracks.
Let me know if I have done anything wrong and please help. I heavily depend on rctech.
rcindia is offline
Old 12-30-2011, 10:26 AM
  #14717
KThatcher's Avatar
Trader Rating: 64 (100%+)
http://www.teamxray.com/teamxray/pro...b5277b32432463
download and read the third PDF its a setup guide from XRAY but it will help you understand what changes you do and how it will effect your car.
KThatcher is offline
Old 12-30-2011, 10:37 AM
  #14718
KThatcher's Avatar
Also here is a set-up for a loose track to get you started just make adjustments as you see fit.
always run your sway bars
File Type: pdf
Old 12-30-2011, 10:54 AM
  #14719
Post some pics of your R's folks..
Herrsavage is offline
Old 12-30-2011, 12:39 PM
  #14720
Sideshow Bob's Avatar
Here are my impressions:
Im still finnishing mine up...screwed up the body...it is really thin on the sides...1mm my bum...anyway one of the scolds i made while cutting out masking tape was obviously too deep and a small flex in the plastic saw it break clean off. other than the sh@tty bitty body - and dog ugly i must add coming from the sleek 2011 808 body - i can honestly say that having never owned anything other than xray's, that this MBX6R was a great build so far. still need to do the shocks.
The build quality is ABSOLUTELY on par wih that of the xray, and that is my honest opinion. Throughout the build I did not once feel i was building something down on quility. There are also a few great solutions on the 6 which i see i'll prefer over the 808. the 6R steering plate/ackerman setup is just WOW, soooo smooth and simple. the xray has a similar solution but i could just never get it as smooth due to figity parts. another thing i instantly noticed while building my 6R was how smooth the drivetrain was, even with brand new sticky bearings still...incredible....and the diff shimming solution...WHY oh WHY cant other manufacturers make it this simple.
Also, the suspension movement is also buttery smooth, another thing you couldnt always get perfect on a 808...i always blamed the swaybars for being to short for this. the center diff setup on the 6R beats the xray to the dust hands-down. just the brakes/diff/pads and fit/look of it all is superior.
I think I can honestly say now that the mugen kit screws are the best i have ever had in ANY kit bar none. they just hold up great!
I can also see myself favoring this pillow ball setup over C-Hub due to the ease of getting all the adjustments without havnig to buy extra caster blocks etc etc. Also an easy way to dail out slop I predict.
All the xtras in this kit are astonishing really. fuel filters, 4 different chassis braces including an AL one, all the plastic versions of the new AL parts as well...you never know when you might need a quick fix all th AL bling....all stuff that i had to get xtra in my 808 kit...even the carbon top plates or AL wing braces arent standard with the 808...so big point here for the 6R.
Im IN LOVE with the look and feel of the drivetrain parts...the silver diffs, outdrives, gear etc ook fantastic and very high quality...BETTER than the "fabled" HUDY spring steel in the 808 kits. the hudy stuff gets ugly after a few weekends anyway and xray stopped hardcoating alot of the shafts and things, substituted them with normal black anodizing which comes off if you look at it to long, my guess is to save costs..especially due to all the xstras they included with the 2011 808.
a few things that were/are mild irritants during the build was
A: getting the plastic bushings seated properly in the AL top arm holder...this was a tight fit...i had to heat up the holder a bit to expand it to get the plastic parts in all the way...nothing major...you probbly dont have to do this if you dont mind skuffing your anodixed bits up with some monkey tool
B: getting the front steering link ends over the ball ends...im not a fan of just guerilla-ing the things in place with some pliers...so i had to take some time getting them on without messing up the plastic. a trick the 808 manual taught me is very handy when geting ball-ends inside link arms...you just use the engine mount block and a normal 16 mm screw or similar....losely place the parts in order on the screw and start tightenng them into te engine mount - which serves merely as a "tapped hole" and just watch everything pop into place without any brute froce. obviosuly this wasnt achievable with the steering links due to the nature of the long all in one ball joint.
thus far, the only thing i still prefer from my 808 is the lower suspension holders/ kickup/ antisquate etc fittings, their system just works easier and better...oh and mugens setup sheets SUCK NUTS
other than that i can say with ease this will be my new Fav car out of the 2 so far, the quality is on par with xray and the 'KISS' solution to alot of areas on the 6R just makes sence, no over complicated junk for the sake of being "innovative". good stuff mugen, you made a believer out of a xray cultist for good
ill post pics of my chassis as soon asi finish the shocks...i hav new bodies on the way so mine wont be painted for a while still...and the old one wich was halfway doen is in the trash now
cheers
Morné
Sideshow Bob is offline
Old 12-30-2011, 12:47 PM
  #14721
I also use the HUDY one, i have it in book form in my box. xray used to provide them in older kits. i have however recently discovered this JQ version too, which is also very easy to understand...especially the quick reference at the end:
http://jq-products.com/the-news/43-t.../160-the-guide
Old 12-30-2011, 12:50 PM
  #14722
Originally Posted by donrod
I agree with Morgoth on 44t spur, we use that on E car but that's about it, it take away to much bottom end we actully go up to the 48 on some tight tracks but the 46 at a min.
so for more acc or bottom end built into the drivetrain you guys go up in center spur gear? makes sense since you cant go down in bell size i guess. im asking since im getting me a .19 speed for the 6R too and ill need all the bottom end i can find i guess...already have a lightweight flywheel/clutch setup for it.
Old 12-30-2011, 01:38 PM
  #14723
Default Mbx6 with +5 chassis
I just bought a used MBX6 and finished installing everything last night. It came with the +5 chassis and 75/8.0 front and 86/8.5 rear springs. Does anyone have a setup guide they could post. I was told shock oil is Mugen 400 rear diffs setup at 5/7/2. He said ride height is already measures around 29 rear 28 front. Side question I use losi ride height gauge do you place tip in center off all four bolts on plate to measure.
speedsterp is offline
Old 12-30-2011, 02:43 PM
  #14724
Company Representative
JoeNolasco's Avatar
Ask and receive my friend!
Click an image to checkout our review for more pics or go to: http://www.p1hobbies.com/blog
JoeNolasco is offline
Old 12-30-2011, 03:18 PM
  #14725
Yes, it lets the motor spool up faster, if you get on a track with allot long straights go back to the 46 or 44 if it's really flat.
donrod is offline
Old 12-30-2011, 05:40 PM
  #14726
CanyonCarverR1's Avatar
Three questions Joe:
1. How's the lateral balance. Would you recommend LiPo? LiFe? cells?
2. Is that a Tamiya pit towel I see in your build review?...WTF?
3. Did you drill the wing buttons? Can't tell what's up with them.
Looks awsome! Can't wait.
CanyonCarverR1 is offline
Old 12-30-2011, 07:23 PM
  #14727
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Donrod - do you recommend the 48 tooth spur for most medium sized US- big jump type tracks then?
Jeff Werner is offline
Old 12-30-2011, 08:35 PM
  #14728
ngo8's Avatar
Those wing buttons are from serpent they are really nice
ngo8 is offline
Old 12-30-2011, 08:37 PM
  #14729
JoeNolasco's Avatar
I recommend the Venom 2400mah Lipo. It fits in the radio box perrrrrfectly. I'm sure it will also fit the forward battery mount. I'm never looking to add steering to my vehicles so that is why I chose to put the battery in the back. As far as lateral balance goes, I'm glad you asked. I just ran out there and "strung" the car by the shock towers and found with an empty tank the car seems just a tiny bit heavier on the engine side. Nothing a couple ounces of lead wouldn't fix! I'll post up on the amount of lead I end up using asap!
Venom Lipo:http://www.p1hobbies.com/venom-5c-7-...flat-lipo.html
Yes! LOL that is a TRF towel! I wish I could get some new ones! HAHA
The wing buttons are actually from Serpent! They are the trickest wing buttons I've ever seen! Blake has been running them on his HB cars for quite some time now... Serpent wing buttons:http://www.p1hobbies.com/serpent-mac...washers-2.html
Old 12-30-2011, 09:34 PM
  #14730
thanks donrod 46/48 it is then....i dont really race on tracks with long straights...more tight and technical stuff.
