Mugen MBX6
You might be over filling them a bit, do you bleed out much oil before
tightening the caps?
Too much oil and too much rebound of the shock shaft will put a lot of preasure on the bladder, bleed out enough oil to have a slow 1/3 to 1/2 rebound.
I also found the bladders swell from the shock oil so replace them every 3 months.
The main reason the bladders collapse especially on the rears is that the piston travels to far up into the cap and the nut pushing them to the top of the cap. If you run the truggy tower or limit the up travel on the shock it will stop most of problem or run the hot bodies bladders.
For those who don't know who I am, I am the old guy that does all the work, Dylan is the young one that does all the driving.
The Food and Drug Administration does extensive tests on pharmaceuticals, but Tylenol doesn't get rid of my headache, advil does
No one said it was an issue. THE CHASSIS ISN'T OPTIMAL; and the same can be said about the 6r's gearing, rear shock geometry, etc......but they still released it.
So if you or anyone wants to get rid of their headache, contact Bill over at BCE and take an X3 for pain.
And no, I'm not sponsored by Advil !
http://www.amainhobbies.com/product_...aintenance-Set
Anyone still use the LOSI bladders?
Maybe it's just down to different track conditions in EU and USA that makes difference in performance of chassis.
Anyway I belive that option parts does what they are supposed to do - transform cars to individual needs and it's nice to have them.
http://www.amainhobbies.com/product_...g-Light-Blue-2
Yes they are and these are the Kyosho springs we are using with the stock buggy tower or truggy tower.
Thank you
+5 chassi all the way! I need all the length I can get. Lol I really like the stock long chassi and don't think I will ever go back to a short one. The 3mm chassi on the bce might be a better option for that chassi cuz its so much stiffer?
Good luck this season Donrod!!
