Mugen MBX6
Mbx6 with +5 chassis
I just bought a used MBX6 and finished installing everything last night. It came with the +5 chassis and 75/8.0 front and 86/8.5 rear springs. Does anyone have a setup guide they could post. I was told shock oil is Mugen 400 rear diffs setup at 5/7/2. He said ride height is already measures around 29 rear 28 front. Side question I use losi ride height gauge do you place tip in center off all four bolts on plate to measure.
Ask and receive my friend!
Click an image to checkout our review for more pics or go to: http://www.p1hobbies.com/blog
so for more acc or bottom end built into the drivetrain you guys go up in center spur gear? makes sense since you cant go down in bell size i guess. im asking since im getting me a .19 speed for the 6R too and ill need all the bottom end i can find i guess...already have a lightweight flywheel/clutch setup for it.
1. How's the lateral balance. Would you recommend LiPo? LiFe? cells?
2. Is that a Tamiya pit towel I see in your build review?...WTF?
3. Did you drill the wing buttons? Can't tell what's up with them.
Looks awsome! Can't wait.
Donrod - do you recommend the 48 tooth spur for most medium sized US- big jump type tracks then?
Those wing buttons are from serpent they are really nice
Venom Lipo:http://www.p1hobbies.com/venom-5c-7-...flat-lipo.html
Yes! LOL that is a TRF towel! I wish I could get some new ones! HAHA
The wing buttons are actually from Serpent! They are the trickest wing buttons I've ever seen! Blake has been running them on his HB cars for quite some time now... Serpent wing buttons:http://www.p1hobbies.com/serpent-mac...washers-2.html
guys, on the included setup sheet (std EU sheet) with the 6R it states reb0und stop at 108mm front...126mm rear...WTH does this mean? 100% rebound? ie shafts fully extended before screwing caps back on? jez...and the on some sheets i se ppl put in like 18mm or 15mm, which i gather from the manual is like ±50%...JEEZ mugen def has to do something about it's retarded sheets...no standard at all
I recommend the Venom 2400mah Lipo. It fits in the radio box perrrrrfectly. I'm sure it will also fit the forward battery mount. I'm never looking to add steering to my vehicles so that is why I chose to put the battery in the back. As far as lateral balance goes, I'm glad you asked. I just ran out there and "strung" the car by the shock towers and found with an empty tank the car seems just a tiny bit heavier on the engine side. Nothing a couple ounces of lead wouldn't fix! I'll post up on the amount of lead I end up using asap!
