Mugen MBX6
i never run the 1 block for the "B block" so im not 100% sure now that i read your post.. if its a -1 then im right. just 1 youre right.
Here are some updated pics with the Carbon stuff from RPM1968 as well as the radio tray from SNR. Everything looks top notch.
damn, son, that buggy is off da hook! nice. where do i get the mudguards?
The page before has all the info. Pm rpm1968 He will hook u up.
Bladders and Werks clutches
Did I read here, or maybe the 6t thread, about using some better bladders than the stock Mugen? I think it might have been Hot Bodys. Can anyone confirm this?
Also, does anyone have any experience with the Werks Pro clutch and the Power clutch, that could explain the difference between the two? I know the physical differences, I'm talking about feel and ajustability.
Brian
Brian
Brian
Brian
Brian
Brian
I've used them and the bladders hold up very well compared to the softer Mugen bladders. HB o-rings fit also but never had any problems with the Mugen rings.
http://www.rctech.net/forum/nitro-of...ml#post9385042
And the link was nice, so I could reread it again.
Cheers
Brian
Brian
Brian
You can also fit within them those filters for hand made cigarrettes and experiment with dampening
Brian
Brian
Have any of you revisited the mugen bladders, I have just replaced mine and the new,ones felt different not as soft as the old ones, might just be age and the oil but If i remember they always were soft even new, can't say the same now though felt much better
I just rebuilt mine with mugen bladders, and they were quite stiff compared to the old ones... But it's nice to know there are alternatives
Truggy Shock Towers on the buggy
Hi
I recently finished my MBX6 buggy and I am very happy with it, but recently I read that some pro drivers use the rear shock tower of the truggy in the buggy and I wanted to ask if someone tried that and if the results are positive... I just want to ask before purchasing anything.
Is it only the rear tower or has someone used the from tower too.
44t?
Hi guys,
short question
i am my way to prepare buggy for 45 min race plus some qualification
i found a 44t conical gear which i can use for front or rear diff.
right now i have standard 42(front)-46(center)-42(rear)
what will happened if i will replace front or rear one for 44t?
is that worthwhile?
short question
is that worthwhile?
