Mugen MBX6
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Actually.... I'm wondering if the RB 2045 pipe will work with the nova?
it might work decent. if i remember right, someone locally ran one on a plus 4 with pretty good results. but if you have it give it a try. if it doesnt work good enough for you, a 053 pipe is a great match for most Novas (def the plus 4), it will have close to the performance as the Nova pipes for half the price.
ty
Can anyone tell me what the part number is for the cross pins in the dogbones? My center driveshaft pins are starting to get worn pins and I'd like to replace them.
I have some left over from my old 808. Would those fit the mugen bones? anyone ever try xray pins? I don't really want to press them out until I know i have something to put back in that will fit.
mugc0271 axle drive shafts 3x13.8mm
The 808 pins should fit but I have never tried so someone else might want to chime in on that one.
Does anybody do the foam behind the shock bladders? What foam do you use?
I just bought a nova 21-4c today, my question is..... will that engine work with a RB Concepts 2045 tuned pipe?
I was running an RB B10, I was very happy with it, but it has 10+ gallons of fuel through it and needs to be rebuilt, I do plan on doing that shortly.
Any thoughts?
Thx,
Lucas
Any thoughts?
Thx,
Lucas
I use losi foams and losi bladders.
Scott
Hi.
I need a front center drivshaft that is 5-7mm longer than the stock MBX6, any ideas?
And then there are these....The are a tight fit but wow.
http://www.amainhobbies.com/product_...-Bladder-Set-4
Only for lovers of full rebound.
My latest setup sheet for anyone interested.
Track was a bit blown out and rutted in the corners, Hard packed with a nice layer of dust on top. Buggy handled it very well, easy to drive, could push it without it getting upset.
Droop measurement is from outside hole on tower to inside hole on Arm.
Ill pick up some to try, thanks
The XRAY changed my
For MUGEN MBX 6 2011
Where can I see examples of setup
