Team Associated 1/8 scale Truggy Info and Tips
#2660
So you saved a few bucks by ordering online. But you are spending a ton of time on here asking questions that could be sorted out at the LHS. Doesn't seem like a good tradeoff.
#2661
um i dint get the part it was the right one in the kit the manual picture on the pin was just confusing me a little bit.
#2663
#2664
i, am taking my time this isnt be first 1/8 kit i ever buildt im just not used to tight fitting parts since ive only put together a losi
yea, i dont think anybody whould say get her done including me with a kyosho kit i was looking into the kyosho truggy before this one.
ajj: i could grind it down on one side but i think when i put the cva clip on it will push the other side out more.
#2665
greg!!!
oh and greg we cut a metal sevo horn as an extension at the front mount and you can either put a spacer at the bottom at other mount to raise it or use a losi tank mount on the rear as its longer.. it easy mod,no drilling,and its 99% necessary because they leak,only thing your bodies have to be cut different cause the cap isnt in same location.. your getting fresh bodies anyway on your new whips... haha
#2666
any pics of how you did this mod to use the losi tank because i have 2 eight 2.0 t tanks ?
the legth you made the metal servo horn at the size of the spacers ?
#2668
#2669
I haven't heard of the tank problem being in the truggys as much as the buggys. Just run that one. I'm almost sure (I can be wrong so don't flame me) that the losi tanks won't fit in the associated.
#2670
what kind of tank troubles do the buggys have? I seem to have a problem with my tank because it seems like it don't wanna push fuel to the carb.
