Team Associated 1/8 scale Truggy Info and Tips >
Old 03-18-2011, 07:13 PM
  #2671
Bugman's Avatar
Originally Posted by ace955
Here are some pics of the D8t fuel tank mod ace955 posted a while ago but like King Revo said if you dont want to move your post,s you can use a cut servo horn
to span the gap here is a pic Team Associated 1/8 scale Truggy Info and Tips-3508941464_6158fb9d3a.jpg you just need a couple washers under your fuel tank posts.
Bugman is offline
Old 03-18-2011, 08:55 PM
  #2672
king revo's Avatar
Trader Rating: 22 (96%+)
Default no
Originally Posted by tc5 man
any pics of how you did this mod to use the losi tank because i have 2 eight 2.0 t tanks ?
the legth you made the metal servo horn at the size of the spacers ?
its a d8 tank dude,only thing slosi is one tank mount because its longer.. run stock for now but be concious of air in line or motor leaning out. Dont jam yourself up anymore dude,run stock maybe youll have a good one,odds are against you though,which is typical.
king revo is offline
Old 03-18-2011, 09:04 PM
  #2673
tc5 man's Avatar
ok thanks no need to be smart about it ok ?
tc5 man is offline
Old 03-18-2011, 11:12 PM
  #2674
RickyBBad's Avatar
TC5 Man LOL The guys on here treat you like Rodney Dangerfield "YOU GET NO RESPECT" AT ALL!
RickyBBad is offline
Old 03-18-2011, 11:39 PM
  #2675
dragracechief's Avatar
Stick with the AE tank for now, I have 2 and have had no issues with either. If you have to, switch when you are done. I think I may have read that some HB guys had some issues with some D8T tanks but I could be wrong.
dragracechief is offline
Old 03-19-2011, 02:49 AM
  #2676
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I like my X2CRT tank...
ajj is offline
Old 03-19-2011, 04:38 AM
  #2677
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by Tim Smith 1416
what kind of tank troubles do the buggys have? I seem to have a problem with my tank because it seems like it don't wanna push fuel to the carb.
It would lean out once the fuel went below the seem. Actually I bought one a couple weekends ago and it was bad out of the bag so I took a soldering iron to the seem to try to seal it up better by melting it. We'll see if it works. but that was the first one in a looonnnng time for me.
TC5man your truck is perfect man!!! Put it together and run it! Don't worry about anything!
Quad Racer 34 is offline
Old 03-19-2011, 06:42 AM
  #2678
Ty Tessman has mods for the D8 and D8T tanks on his website. It's mainly on the lines going in the tank because they can fail. Even on his HB stuff.
Chris Reilly is offline
Old 03-19-2011, 11:48 AM
  #2679
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Bugman,
Those pics you linked up are what I did to my chassis. Not too hard to do. Went with the HB tank and haven't had issues.
Teufel Racing is offline
Old 03-19-2011, 12:08 PM
  #2680
Audiobahnaholic's Avatar
Trader Rating: 44 (96%+)
I did the d8T mod but i put the servo horn under the tank post. Much cleaner factory look
Audiobahnaholic is offline
Old 03-19-2011, 02:46 PM
  #2681
Bugman's Avatar
Originally Posted by Teufel Racing
Bugman,
That,s what i did too, I also used the the odonnell zo1t fuel posts work,s good just have to grind the nub at the bottom of the post,s
Bugman is offline
Old 03-19-2011, 07:23 PM
  #2682
t4ftracer's Avatar
Trader Rating: 73 (100%+)
my man welcome to associated,and a congatulations to his son 'gunnar' for picking up a well deserved AE ride after motorama..
thanks for the kind words king. We look forward to running and dialing in our new ae rides. Should be here end of next week.
Regarding the tank, I (or no one else) actually said there was a tank issue, just questions about what others used and how they mounted up and final results, that's all....Our stuff will be built all original. Then if a problem arises in testing, I'll address it accordingly. There is no need to frankenstein up your ride before you even know how it performs in stock trim, right?
t4ftracer is offline
Old 03-19-2011, 07:42 PM
  #2683
tc5 man's Avatar
ok, i did page 10 bag D and i inserted the steering block bushings into the steering blocks and put locktite on the screws that go into the steering knockles .
heres, my question it show that the steering block bushings go into the steering blocks with the trangle facing up so when i was tightening them down did did the bushings key into the blocks right ?
the screws did tighten all the way and it was smooth .
tc5 man is offline
Old 03-19-2011, 08:31 PM
  #2684
Mikey Hudson's Avatar
You are correct. The triangles key into the steering knuckle. Sounds like you got it right, everything should be smooth with no binding
Mikey Hudson is offline
Old 03-19-2011, 09:09 PM
  #2685
tc5 man's Avatar
ok, but i mounted the steering block nushings where the triangle is upwards like the picture shows i must of did it right because theres no binding at all and smooth.
so with the triangle facing upwards into the block it stills locked into the steering knuckle ?
tc5 man is offline
