Team Associated 1/8 scale Truggy Info and Tips >
Old 04-01-2011, 08:19 PM
  #2806
cdo
cdo's Avatar
Trader Rating: 58 (100%+)
Originally Posted by jenson40
i replaced the o-rings in my rtr rc8t, i know they had a running change , the ones i put in are clear . Are the clear ones the updated ones or the black ones?
The clear ones are the new ones.
cdo is offline
  #2807
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Clear ones are the new ones. .
Brad
Brad S. is offline
Old 04-01-2011, 08:24 PM
  #2808
thanks
jenson40 is offline
Old 04-01-2011, 08:27 PM
  #2809
mgtmadness2007's Avatar
Jenson- PM Sent
mgtmadness2007 is offline
Old 04-01-2011, 09:46 PM
  #2810
tc5 man's Avatar
has, anybody have this problem i filled my shocks up to 1mm from the top and i stick the bladder inside the cap and than screw it on the cap and when i push the shock shaft up a little oil comes out of the hole everytime when im checking the rebound
and the bladder is seated inside the cap and it doesnt feel like to much oil pushing the shaft up .
tc5 man is offline
Old 04-01-2011, 10:04 PM
  #2811
I havent had that problem. if oil comes out of the hole then, the bladder is not seated all the way into the cap. Also if it is too tight it may twist the bladder, making oil leak out.
Old 04-01-2011, 10:11 PM
  #2812
tc5 man's Avatar
i think maybe i overtighten the cap likely because i made sure the bladder was seated good inside the cap.
il just tighten the cap intill its just snug no more than that.
tc5 man is offline
Old 04-01-2011, 10:17 PM
  #2813
Did you take an allen wrench or something and kinda push on the ridge of the bladder lightly till it moved past the threads? And I usually put a lil oil around the edge of the bladders before i put them in. idk if the CE manual suggests that or not.
Old 04-01-2011, 10:22 PM
  #2814
tc5 man's Avatar
i used a flat head to make sure it was seated i dint stab it so i whould i whouldnt rip the bladder it was past the threads though into the cap .
i dint use oil on the bladder around the edge il try that to and the ce manuel doesnt say that.
tc5 man is offline
Old 04-01-2011, 10:27 PM
  #2815
ok, cool.
Old 04-01-2011, 10:32 PM
  #2816
tc5 man's Avatar
ok, cool.
i, know it says also to screw the shock ball end to the eyelid on the manuel and thats not fully tighten just snug flush with the eyelid but when i took the shocks out of the bag it was pasted the eyelid and fully tighten so i guess thats the way to do it screw it on intill its fully tight.
i dont know if yours was like that also out of the box also ?
tc5 man is offline
Old 04-02-2011, 12:34 PM
  #2817
tc5 man's Avatar
ok, this is weird i made sure the shock bladder was seated inside the cap and i even try to fill the shock all the way to the top and i bleed them right.
with the oil and bubbles comeing out of the shock cap and i just tighten it intill it was snug and when i push the shaft up a little bit of oil comes out
the shock doesnt go all the way down on the treads i dont know if that has something to do with it ?
tc5 man is offline
Old 04-02-2011, 12:35 PM
  #2818
tc5 man's Avatar
with, the oil and bubbles comeing out of the shock cap and i just tighten it intill it was snug and when i push the shaft up a little bit of oil comes out
the bladder looks fine .
nevermind, i think i fixed it i had to fully tighten the shock cap intill it couldnt tighten no more and i dint see oil come out of the hole on the cap when i pushed the shaft up and only a little bit of the threads showed on the shock body.
tc5 man is offline
Old 04-02-2011, 03:25 PM
  #2819
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Here are 5 set-up videos.
TC5 Man you need to watch these.
RMKinWI is offline
Old 04-02-2011, 03:42 PM
  #2820
tc5 man's Avatar
thanks for the link i fixed the problem now though no oil is coming out of the cap hole since i fully tighten the cap.
tc5 man is offline
