Team Associated 1/8 scale Truggy Info and Tips >
Old 02-01-2010, 12:00 AM
  #1156
mine is the rc8t FT ,thinking to get the front battery box before ,but i realized that my nimh batt. pack is big its the ballistic 2700 batt. & yes on my experience it will give more steering cause of the weight really wanted to try lipos but i guess no need ,we dont do 45 mins. main even 30 mins. hope it helps
mbx5rcr34 is offline
Old 02-01-2010, 04:32 AM
  #1157
flippz's Avatar
me and a fellow racer both have the foward battery box and im on nimh and he is running lipo. in a side by side comparison we can not tell a diffrence. he has a reedy 2100 lipo in the box. the only advantage is he gets to charge once to my three but i have three packs. i charge the night before and peakl at the track with no concerns.
flippz is offline
Old 02-01-2010, 05:03 AM
  #1158
Default Steering servo horn ?
How is the stock plastic servo horn holding up on the RC8T? I tried mounting a stock Hitec (ones that comes with servo), and even the shortest arm would rub against the forward mounted battery box. Any recommended aftermarket servo horns ?
Ramirez24 is offline
Old 02-01-2010, 11:20 AM
  #1159
Midnight's Avatar
Trader Rating: 87 (100%+)
Originally Posted by TXRC8racer
This is a truggy I traded for about a month ago, I have pretty much have a new truck now thanks to ebay but I still can not see paying 60+ dollars apiece for the CE shock towers. But this truck has every thing but the towers. This is my first truck and can not wait to get it on the track.
Just waiting on my KustomRCgraphics Jconcepts Punisher body..
Hey Tx I was admiring your truck and noticed that your fuel line might be getting rubbed by your brake linkage. I moved mine to the other side of the filter.
Midnight is offline
Old 02-01-2010, 01:06 PM
  #1160
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i've been running the dynamite ones, doubled up, and they touch enough to leave a mark, thats it. you can go in a hole on any arm, just have to dremel some off the end maybe.
j_blaze14 is offline
Old 02-01-2010, 01:19 PM
  #1161
RC-ZOMBIE's Avatar
stay with the stock plastic, unless you want to waste $
RC-ZOMBIE is offline
Old 02-01-2010, 02:26 PM
  #1162
NJA82's Avatar
Trader Rating: 33 (100%+)
You talking about servo horns? hmmm im not going to agree with that one, ive seen many strip out, i would definately invest in an alloy steering servo horn at a minimum, the throttle one works fine plastic.
NJA82 is offline
Old 02-01-2010, 02:35 PM
  #1163
RC-ZOMBIE's Avatar
I have never had any problems 20+ yrs racing with the plastic ones but thats just me, I know alot who have problems and there servo saver is too tight or roll there buggy or whatever after every jump.I would rather a $1.50 servo horn strip than replace a $100.00 servo IMO.
Old 02-01-2010, 03:53 PM
  #1164
flippz's Avatar
i just got the racers edge servo arm for futaba. i like a soft servo saver but not a floppy servo arm. seems to be the ticket for me and works goood. nothing wrong with the plastic horn it just hurts my feelings to look at such a beautiful creation and see plastic that is not involved with the gas tank. could be a bling thing but what ever works for you keep it going!
flippz is offline
Old 02-01-2010, 05:58 PM
  #1165
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
Yes it was, but it was not race ready, still got some little odd stuff to do lso put it on a board before it hits the track..
TXRC8racer is offline
Old 02-02-2010, 11:31 PM
  #1166
vti-chris's Avatar
Default steering knuckle problem
I encountered a problem with my new RC8B build.
It looks like the bushings that go through the front hub and helps to bolt the knuckle in and turn, is a bit too short.
This causes the screw to bind on the plastic hub instead on sitting on the bushing and causes a bind in the steering system.
Anyone encountered this before...any fixes???
vti-chris is offline
Old 02-02-2010, 11:41 PM
  #1167
Bigedmond's Avatar
Trader Rating: 20 (100%+)
There are 2 sizes of bushings. The top get the short ones while the bottom get the longer bushings. IRC. ALSO, make sure you locktite the hell out of those screws.
Bigedmond is offline
Old 02-02-2010, 11:42 PM
  #1168
killermmn's Avatar
x2
killermmn is offline
Old 02-03-2010, 01:08 AM
  #1169
vti-chris's Avatar
Yes i know about the 2 different sizes. But even with the longer one it still needs a bit more to save it from binding.
No-one else has experience this with the car?
Old 02-03-2010, 03:57 AM
  #1170
Shane Racer's Avatar
In some cases the bushings fit in the caster block to tight. That's why it does not rotate freely. Use a round file and ream the hole out a little until the bushings slide in and out freely.
Shane Racer is offline
