Team Associated 1/8 scale Truggy Info and Tips >
Old 03-17-2011, 08:43 PM
  #2641
dragracechief's Avatar
Originally Posted by tc5 man
i, put together the front end axles and noticed the back and forth play i guess thats ok ? i did notice some metal burrs around the axle so i had to smooth them out .
i, dint get to do the front center axle because im missing the pin that has a ingrave into it so i have to call associated and no i dint lose it .
how can you tell when they ware than ?
The pin in the center cvd's are smooth, no engraving or indentations and are just held in by the retainer rings. During regular maintenace when you check the pins you can tell when they are worn.
dragracechief is offline
Old 03-17-2011, 08:54 PM
  #2642
tc5 man's Avatar
in the manuel though by looking at the picture it looks like a pin with a engrave in it .
look at it real close .
i know there isnt a set screw that holds it and just the pin.
its on page 8 bag D.
tc5 man is offline
Old 03-17-2011, 09:02 PM
  #2643
I know it looks like it but there isn't, its just smooth. Since there isn't a setscrew no reason for it. All of mine on both truggy and buggy are this way.
Old 03-17-2011, 09:06 PM
  #2644
tc5 man's Avatar
ok, thanks i did try the smooth pin that came in bag D and i lined up the cva cup with the axle stub and the pin is kind of hard to get in its the right one to ?
it will go though the cva cup but its hard to get though the coupler ?
tc5 man is offline
Old 03-17-2011, 09:11 PM
  #2645
If it was in bag D and fits in the coupler its correct. All the pins are smooth.
Old 03-17-2011, 09:15 PM
  #2646
tc5 man's Avatar
ok, yea it fits though the cva cup and when i line up the coupler with the holes in cva cup its hard to get it though the coupler for some reason ?
its tight .
it was in bag d.
yea the pin is smooth.
tc5 man is offline
Old 03-17-2011, 09:17 PM
  #2647
Your good to go.
Old 03-17-2011, 09:19 PM
  #2648
tc5 man's Avatar
Your good to go.
oh so the tightest is fine just have to use some muscle into it ?
ok i got it though man it was tight !
but, is it fine that one side of the pin is in more that the other or having the clip on it push it to have even sides ?
tc5 man is offline
Old 03-18-2011, 05:34 AM
  #2649
RickyBBad's Avatar
WOW tc5 man! Your having trouble with every bag you open. Take your time bro and read the manual. Its all there and so are the parts. If you was building a Kyosho kit you would never lets say "GET HER DONE" LOL
RickyBBad is offline
Old 03-18-2011, 05:37 AM
  #2650
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
The pin will be tight. I still have to insert mine halfway then press them on the bench sometimes. If it's to long just grind it down a little, but I imagine it wouldn't be long enough to worry about...
ajj is offline
Old 03-18-2011, 05:50 AM
  #2651
AlanHall's Avatar
Trader Rating: 43 (100%+)
LoL. More "missing" parts . Dude you got to stop saying AE forgot your parts cause you can't figure it out. Relax and think about what your doing. Surely while searching for the pin you THOUGHT you needed you ran accross the correct part.
AlanHall is offline
Old 03-18-2011, 06:03 AM
  #2652
RickyBBad's Avatar
I built and painted Four kits in a little over a week RC8T, RC8Be, SC10 and RC10 T4.1 and every part was present. the only issue i had was one bad bearing. The hardest thing that i had to do was pulling that rubber boot over the cvd bone. I had fun putting the kits together and im currently waiting on the SC10 4x4.
Attached Thumbnails Team Associated 1/8 scale Truggy Info and Tips-imag0383.jpg   Team Associated 1/8 scale Truggy Info and Tips-imag0380.jpg   Team Associated 1/8 scale Truggy Info and Tips-imag0371.jpg   Team Associated 1/8 scale Truggy Info and Tips-imag0386.jpg   Team Associated 1/8 scale Truggy Info and Tips-imag0381.jpg
Old 03-18-2011, 07:07 AM
  #2653
Rodrigo360's Avatar
Originally Posted by AlanHall
What fuel tank is that?
I don't know, the truggy comes with it, I read something about tank troubles on the thread and decide not change that tank, i think that this is from HB D8T.
Rodrigo360 is offline
Old 03-18-2011, 08:41 AM
  #2654
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Yup it's a D8T tank,
I have one in mine now as well. The stock tanks were a little too hit or miss for me. I really wish the folks at Associated would correct that. The tank issue has been my only real issue with the truck. The rest has either been me, a setup issue, or both.
Teufel Racing is offline
  #2655
t4ftracer's Avatar
Trader Rating: 73 (100%+)
Looks like a D8T tank to me as well.
t4ftracer is offline
