RC10B4.1 FT/WC
Old 03-25-2012 | 11:02 AM
  #13126
jccj816's Avatar
R/C Tech Elite Member
Smile
Bought a new Worlds kit and raced it for the first time lastnight. Tq'd and won a-main for the first time ever. It was a good night. I used the factory set up except for rear shocks I went with 27.5wt. Had to share the excitement with someone.
jccj816 is offline
Old 03-25-2012 | 11:20 AM
  #13127
idrummerboy13's Avatar
wow thats great nice! Won with mine friday night in 13.5. track was dryer out so it can be broken up for this weekends layout change. Felt horrible but i pulled the win.
Threw on maifields reedy setup to try for new layout..Zeroed out all my settings speedo and radio. Scuffed tires-IM SET!
idrummerboy13 is offline
Old 03-25-2012 | 11:58 AM
  #13128
mxracer458's Avatar
i can push my worlds car so much more then my trf 201,the 201 just felt like it was on the edge all the time,couldn't really push it because either the front was good and the rear was bad or vice versa,can't wait to run this at west coast and see how does on a track with good traction.
mxracer458 is offline
Old 03-25-2012 | 12:19 PM
  #13129
Aoh
I see this mentioned here and there, can anyone explain how I do this?
Aoh is offline
Old 03-25-2012 | 01:12 PM
  #13130
when the new tires are worn in a little, they get better and better, just run them.
Old 03-25-2012 | 01:58 PM
  #13131
Originally Posted by ChadB.
I am need of some help. I am running Cavalieri's Reedy Race set-up with some minor changes. 32.5 shock oil up front, spindle up, Pink Kyosho spring up front and White in the rear. I am lacking low speed turn in, it has a high speed push and just rotates through the corner really slow. I am about 1.5 sec. a lap slower than the top 5 leaders. I run mod with an 8.5 with pink tapers up front and pink BK Bar in the back.
I am also wondering what everyone is using for a toe block? I have 3 degrees. Any help would be great.
Try 27.5 front and 25 rear! I ran 32.5 up front and had the same problem try the lighter oil!
bigdog is offline
Old 03-25-2012 | 02:10 PM
  #13132
1Fastpede's Avatar
Part # for blue spacers under ballstuds? i see small dia. ones on knuckle and bigger ones on tower
1Fastpede is offline
Old 03-25-2012 | 02:24 PM
  #13133
ChadB.'s Avatar
Thanks, I'll have to give it a try. What about the toe block, what is everyone using?
ChadB. is offline
Old 03-25-2012 | 02:37 PM
  #13134
OptimumRC's Avatar
The larger diameter washer I think is #4617 and the other small diameter washer is #31286.
OptimumRC is offline
Old 03-25-2012 | 03:22 PM
  #13135
1Fastpede's Avatar
thank you!
Old 03-25-2012 | 04:25 PM
  #13136
raceseeker's Avatar
Are Those the New Associated Big Bores
raceseeker is offline
Old 03-25-2012 | 04:38 PM
  #13137
1Fastpede's Avatar
revtech rotor same as duo3?
Old 03-25-2012 | 04:51 PM
  #13138
Buckaroo's Avatar
No. The Rev is strictly for blinky (doesn't tolerate electronic timing advance well at all!!!), the duo will handle blinky or boost.
Different power bands, different feel.
Buckaroo is offline
Old 03-25-2012 | 04:57 PM
  #13139
Teambcw's Avatar
yes
Teambcw is offline
Old 03-25-2012 | 05:13 PM
  #13140
I like to start with the .5 hub carrier blocks to start then the 3.5 toe block! It all depends on your track surface! If you have a higher bite track the 0 hub blocks let the car rotate in the corners better.
bigdog is offline
