RC10B4.1 FT/WC
Old 09-02-2011 | 10:06 AM
  #5626
Wild Cherry's Avatar
Tech Legend
Originally Posted by tkge
Just want some suggestions on how to get some of the on power push out of this car. I have the Maifield Reedy race setup on it with the exception of orange Kyosho springs up front and black Kyosho ones on rear. This buggy handles great and drives good, I just want it little more dialed!
Check & see if your slipper is way tight ....
Ft end should rise no more than a 1 in while holding it down for slipper test.
Wild Cherry is offline
Old 09-02-2011 | 10:09 AM
  #5627
tkge's Avatar
Slipper is good, it dont really raise up the front much because at times the track is really loose. I test it out on the table and the carpet, then fine tune it at the track, I can hear it slipping when on the throttle.
tkge is offline
Old 09-02-2011 | 10:59 AM
  #5628
idrummerboy13's Avatar
run the cav 2010 hrh shoot out setup it is really good, try running 3.0 degrees of rear toe and maybe dk yellow k springs or yellow k springs so the rear can get loose but not in a bad way
idrummerboy13 is offline
Old 09-02-2011 | 12:13 PM
  #5629
bds81175's Avatar
Moderator
Diff too tight?
bds81175 is offline
Old 09-02-2011 | 01:05 PM
  #5630
tecniquin2001's Avatar
Instead of the 3 shock limiters up front, use 4 limiters, this will give you good on power turning.
It reduces front droop.
tecniquin2001 is offline
Old 09-02-2011 | 03:37 PM
  #5631
916bdogg's Avatar
Default AE Is Killer Of All......
Originally Posted by bilster44
Detailing off road cars?
C'mon what you know you pulls yours apart every night !~ bahaha
916bdogg is offline
Old 09-02-2011 | 03:57 PM
  #5632
Jmuck69's Avatar
I tried the WD40 and Endust last night cleaning mine while putting the +8 chassis on. WD40 is far better and I like the smell. I was using green apple scented Endust which did not give the performance I need, so will try lemon scented next time.
Jmuck69 is offline
Old 09-02-2011 | 04:03 PM
  #5633
Tech Legend
Almost no one
nobody uses the Wd around here, its
all Endust if you look in the pits ...
Old 09-02-2011 | 06:01 PM
  #5634
Jmuck69's Avatar
Originally Posted by Wild Cherry
Almost no one
Jmuck69 is offline
Old 09-02-2011 | 06:26 PM
  #5635
Just wanted to share some pics of my 8mm+ b4 and my new finnisher body painted by paint monster.
Bmarsh is offline
Old 09-03-2011 | 08:18 AM
  #5636
Mach10_shooter's Avatar
Nice job...
Mach10_shooter is offline
Old 09-03-2011 | 11:47 AM
  #5637
lip
Originally Posted by Asharus
Get the SC10 ball diff, the old ball diff kits are for the B4 tranny and don't have the notch to make it fit properly.
Get the RPM Long Shank cups with the notch in it to allow for more travel.
Thanks.
So the B4.1 FT ball diff would not work?
LIP
lip is offline
Old 09-03-2011 | 11:49 AM
  #5638
lip
Originally Posted by D-Rek07
Unless you can save on shipping or something, I would order off of amain because all their is always a few dollars cheaper than the associated website.
Oh I would not order from associated direct...I always go with amain.
Can someone help me with my question about going from the standard blue b4.1 shocks to the FT shocks...do I need to buy the whole shock kit or can I get away with just some of the parts?
Thanks.
LIP
lip is offline
Old 09-03-2011 | 11:53 AM
  #5639
Matt Trimmings's Avatar
Thanks.
LIP
You would need to buy the bodies and seal kit, you might be better off getting the kits because they also come with the titanium nitride coated shock shafts. Fronts are .89 and the rears are 1.18.
Matt Trimmings is offline
Old 09-03-2011 | 11:56 AM
  #5640
Thanks.
LIP
The ball diff you would need is part number ASC9853. The b4.1 ball diff is not available in a kit to my knowledge, the b4 is but it has different sized outdrives (std bearing size, b4.1 and sc10 use metric bearings).
