RC10B4.1 FT/WC
Old 09-09-2011 | 09:25 PM
  #5776
Jmuck69's Avatar
Originally Posted by ovalracer1m
I believe all you would need Is the t4.1 diff cases, outdrive bearings, and of course the diff itself. Outdrive Bearings are metric 10x16 on the 4.1 and 3/8x5/8 on the standard t4 so these parts are needed
http://www.amainhobbies.com/product_...Ball-Bearing-2
http://www.amainhobbies.com/product_...nsmission-Case
http://www.amainhobbies.com/product_...r-Differential
You will also need the rear T-plate for a SC10
Jmuck69 is offline
  #5777
Thank you sir,
rifraf is offline
Old 09-09-2011 | 09:40 PM
  #5778
racer1812's Avatar
Super Moderator
Originally Posted by Matt Trimmings
Dont mean to burst your bubble but the chassis is the same for the rtr. ASC7440 is the only part number for a t4 chassis.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFDV2&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXFDV1&P=7
AE #7440 vs. AE #7441
It's not the only part number but it seems to be the correct one as to not get the stiffer carbon chassis of old....$17 cheaper too
racer1812 is offline
Old 09-09-2011 | 10:06 PM
  #5779
D-Rek07's Avatar
Originally Posted by Jmuck69
No, attracts too much dust.
Wouldn't a little cleaning be worth not having to replace outdrives as often?
D-Rek07 is offline
Old 09-09-2011 | 10:54 PM
  #5780
Jake S's Avatar
Originally Posted by t-roth
Will the GensAce 5000 mah batterys that are 25mm high fit in the b4.1 chassis? I tried in my old T4 but it will only fit if I put the battery all the way forward and flex the battery strap at the back.
its not the chassis that matters. the 4.1 rear towers have more clearance for the battery strap. in a 4.1 it will fit much easier than an old "4" tower.
this was a rolling change because lipos are alittle taller than nimhs that the b4/t4 was designed for.
that being said, YES the gens will fit in the b4.1 chassis. in a t4, generally you dont run your battery all the way back (atleast 1 spacer in the rear)
but if you meant on a b4, yes it is tight, untill you change to a b4.1 rear tower.
Jake S is offline
Old 09-09-2011 | 11:00 PM
  #5781
Jake S's Avatar
Originally Posted by D-Rek07
Does anyone grease the dogbones into the diff outdrives to prevent wear?
not a paste / liquid... i would think a "dry" teflon grease would help some, but its not the in and out that wears them, its when you accel. it really isnt anything that will help this wear, if your outdrives are wearing alot, maybe using the rtr outdrives would increase the life (the lightweight/factory ones are alittle "softer")
Jake S is offline
Old 09-09-2011 | 11:55 PM
  #5782
Matt Trimmings's Avatar
I was speaking of plastic chassis'. The rtr and the ft have the same number for the plastic chassis. The only way, at this moment, to get a t4.1 chassis is to check eBay for the guys that buy a kit and part it all out.
Matt Trimmings is offline
Old 09-10-2011 | 05:05 AM
  #5783
xtraman122's Avatar
Like Matt said, when they went to the "4.1" kits, they just began using what used to be the old school RTR plastic, so things like arms, towers, and chassis', just use the same old part numbers because they've always had the parts.
Most everyone that's been making the extended chassis' has been using the "RTR" (now FT) chassis, which is what they use on the new kits from the get go.
xtraman122 is offline
Old 09-10-2011 | 05:15 AM
  #5784
Jmuck69's Avatar
I do not run the current diff outdrives but the older style transmission.
http://www.teamassociated.com/parts/details/7678/
http://www.teamassociated.com/parts/details/9574/
plus the B4 rear T-plate. The older outdrives do not wear nearly as fast. i have had an "older" diff in for quite a while and has shown very little wear in the outdrives. the lightened stuff is way too soft. If you use the older diff, make sure to use the newer tan colored diff gear. The older black gear comes with the kit and it is crap.
Jmuck69 is offline
Old 09-10-2011 | 05:59 AM
  #5785
Actually we have been using the original plastic chassis and not the newer 4.1 plastics. Reason is because that is all that available. I talked to AE's team manager a while back and he said that the reason they made all of their chassis' out of the old plastic is because that's all they had. So I'm guessing it's going to be awhile before we see the new .1 plastic chassis.
Old 09-10-2011 | 06:24 AM
  #5786
xtraman122's Avatar
Yeah I guess I was just referring to using the part number as them, isn't the plastic itself the same though? Unless it's supposed to be the stiffness of the B44 plastic. I can't see them not selling any parts in the plastic if the new kits actually do have a different formula than what the original "plastic" was.
Old 09-10-2011 | 06:48 AM
  #5787
bds81175's Avatar
Moderator
I've been running the older black gear from day one. What have you found that's wrong with it? What benefit would I get by replacing it with the tan gear?
bds81175 is offline
Old 09-10-2011 | 07:12 AM
  #5788
Jmuck69's Avatar
I found that the black material was breaking down and turning to powder. It would load up between the teeth making it loud and not very smooth. replaced it with the tan gear and it was solved.
Jmuck69 is offline
Old 09-10-2011 | 07:20 AM
  #5789
bds81175's Avatar
Moderator
10-4 I rebuild my diff often (I sadistically enjoy it) so I'll check the condition of the gear next time I do.
bds81175 is offline
Old 09-10-2011 | 07:27 AM
  #5790
You can not purchase the t4.1 chassis at this time due to the large stock of the original t4 chassis that still exists. This is a different material as the newer t4.1 plastic has more flex to it.
