RC10B4.1 FT/WC
Old 09-11-2011 | 12:23 PM
  #5806
Dave De Voe's Avatar
Originally Posted by Brad S.
#9880 - Steering Block SC10
#9881 - Front Axle/Hex
Then you just need some drive pins, and axle shims. I already had hexes on the rear of my B4.1 (RB5 rear hexes), so I went ahead and bought
#7497, which includes all the pins, and some hexes for my B4.
Brad
Thanks alot.will be checking this out soon
Dave De Voe is offline
Old 09-11-2011 | 05:07 PM
  #5807
Exclamation WEIGHT???
While reading all of these setup sheets online and on forums I keep seeing this much weight here and this much there....but how does the car weigh when all is said and done (total weight)....If your buggy ends up at 2000 grams it's a pig and needs a diet.I would just like to see total weight on these sheets.....JUST A THOUGHT.
Old 09-11-2011 | 05:13 PM
  #5808
Teambcw's Avatar
just add weight as desired and weigh your buggy.
Teambcw is offline
Old 09-11-2011 | 06:19 PM
  #5809
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by Blue Screw
Ok guys a couple things here that i did and notice since signing with AE/REEDY/LRP/JC.
But since i still need to get stuff striaght i ran a x12 10.5 24/81 but honestly it didnt matter i was having diff and slipper probs come to find out. Umm i use ae cermics diff balls/bfast rings/bfast thrustrings and cermic balls. do you think with going with all cermics it didnt have enough grip to grab the rings?
- stupid question even though its a short neckball stud why do they have a black one and a silver one i mean obviously i replaced them with the new ae gold ti ones but still?
Of all the people to answer first, right?
The diff slippage is from the ceramic balls, they are so smooth and hard the balls actually have less grip than the carbide balls. I sand my diff rings with 400 grit sandpaper when using ceramic diff balls. Since the diff balls have no grip, you have to give the rings grip. Of course sanding the rings will have to be done as part of maintenance now because the harder diff balls will eventually polish a groove into the diff rings causing the slip to come back. I'm actually considering switching to carbide diff balls and using ceramic for the thrust balls.
The short neck (black) ballstuds are used on the steering rack. It affects bump steer I think in a way that settles the front end down in the bumpy parts.
Those are the questions I had an answer for. Hope it was helpful.
SpraydbySprague is offline
Old 09-11-2011 | 06:49 PM
  #5810
After spending a winter with a 12R5.1 weight is critical and is so-in-so has an extra 20 grams added to his car how far over weight is he and if he isn't over than that changes everything......ea..lighter turns fasster and that means everything!
Old 09-11-2011 | 07:55 PM
  #5811
bds81175's Avatar
Moderator
Not necessarily for mod. In mod you have more than enough power to move around a few extra grams of weight. And you are placing those grams inside the wheel base to counter weight outside the wheel base (the motor). I would agree, in the past you always wanted to be at the absolute min. weight. Not so much anymore.
bds81175 is offline
Old 09-11-2011 | 08:01 PM
  #5812
JFuel11's Avatar
Default Weight...
There seems to have been a lot of discussion around weight the past few days. I user a fair amount of weight on my b4.1. These mod buggies are so fast with brushless motors that it helps to add some weight to the key areas of these cars. 1. to keep the nose down on high traction and two to balance out the chassis side to side as the esc and wire are actually alot more weight than the rx and transponder. Addiont weight is a good thing when used correclty. It does not matter how you lower lap times... If you can drive it more consistant, with better forward bit I don't see any issue with that...
JFuel11 is offline
Old 09-11-2011 | 08:48 PM
  #5813
has anyone boiled there chassis to to try and gain more flex? I have done this in the past with arms...
bmsgangster is offline
Old 09-11-2011 | 09:32 PM
  #5814
BrentH's Avatar
Just curious, how long ago was it when you boiled arms? I'm curious only because I remember guys talking about this in the late 80's. I just can't see today's materials holding up well after a boiling, not to mention have more flex...
I'm pretty sure the b4.1 chassis has plenty of flex. Maybe you should try one of my Chassis's.
BrentH is offline
Old 09-11-2011 | 10:03 PM
  #5815
Originally Posted by ovalracer1m
I believe all you would need Is the t4.1 diff cases, outdrive bearings, and of course the diff itself. Outdrive Bearings are metric 10x16 on the 4.1 and 3/8x5/8 on the standard t4 so these parts are needed
http://www.amainhobbies.com/product_...Ball-Bearing-2
http://www.amainhobbies.com/product_...nsmission-Case
http://www.amainhobbies.com/product_...r-Differential
Associated at one point made a complete ball diff kit for the SC10 that could also be used on a T4. I bought one when I changed my RTR T4.1 to a full blown T4.1, Cannot seem to locate it now, but it came with everything you needed and was fairly cheap.
Never mind I read it wrong, I thought the poster wanted to go from gear to ball diff. Sorry
jpcopeland1 is offline
Old 09-12-2011 | 04:14 AM
  #5816
Hello I've been out of 1/10 th scale electric for a long time and decided to break out the b4 for a while. I need some help with buying a brushless system and the difference between stock and mod.... The last time I raced this thing all I had was a trinity 27 turn and a 3300 reedy packs...so all help will be appreciated
mwitham87 is offline
Old 09-12-2011 | 04:45 AM
  #5817
bds81175's Avatar
Moderator
At this point, I'm only familiar with mod. A 5700kv motor is about all you will need for a B4. You will find the front end trying to climb into the sky if you aren't judicious with the throttle. I've got a Castle Mamba Max Pro. Love it. Sensored motors are a bit smoother on the bottom end. Tekin and LRP seem to be pretty popular brands. Battery tech has come a huge way too. Check out Gens Ace lipo's. They are dirt cheap and I have had great success with them.
bds81175 is offline
Old 09-12-2011 | 05:00 AM
  #5818
Ok yeah I wanna run both and just not sure what to get as far as stock and mod ......as far as batteries are concerned I've found promatch to be pretty cheap to and they are getting great comments.....plus I know someone that was sponsored with them
Old 09-12-2011 | 05:58 AM
  #5819
racer1812's Avatar
Super Moderator
Stock is going to be a 17.5 turn motor just about anywhere you go, you'll also have to find out if they run "boosted" or no timing. Mod is normally 7.5-10.5, it's all up to you.
racer1812 is offline
Old 09-12-2011 | 06:10 AM
  #5820
racer1812's Avatar
Super Moderator
Is this pretty much the standard grit people are using to sand the rings when running the ceramic balls? I haven't run ceramics in a LOOONG time. With carbide's I normally sand with 400 then 600.
