RC10B4.1 FT/WC
Old 07-25-2011 | 02:06 PM
  #4306
Asharus's Avatar
Originally Posted by bilster44
I do have them, and have since they were only available on AE's site. What is frustrating about them is, the ballstud seems to come loose on tracks that seem to have a lot more turns one way than the other. The little aluminum lock nut vibrates loose and the ballstud starts moving around and that's no good. Would like to find some tiny lock washers and use the tiny flat nuts from AE with a drop of loctite to see if both sides will stay tight. Any idea's?
I had that problem with the top shock bushings. Locktite and a tiny washer on the cap head screw fixed it.
Asharus is offline
Old 07-25-2011 | 02:14 PM
  #4307
What are you guys using to give your wings that hazy look?
jpcopeland1 is offline
Old 07-25-2011 | 02:27 PM
  #4308
Scotch bright or ultra fine sand paper works for me.
JW91 is offline
Old 07-25-2011 | 02:29 PM
  #4309
mellow's Avatar
Scotch brite both sides and you've got yourself one clean looking wing!...oops beat me to it.
mellow is offline
Old 07-25-2011 | 04:10 PM
  #4310
DirtRacer68's Avatar
Originally Posted by Asharus
I temp at about 140ish max after a main or qualifier. Usually in the 130 range though.
I think 75/30 is perfect for the 13.5. I did temp at 160ish one time, but that was after a loooooooong practice run.
I gear my SC10 17.5 at 75/26. If I go anywhere beyond the 6-8 min mark, The temps rise above 160, so I try not to take more than 1 or 2 hot laps before the mains.
Is the SC10 17.5 using any boost and if so, how much?
DirtRacer68 is offline
Old 07-25-2011 | 04:14 PM
  #4311
Jake S's Avatar
im running 75/30 on a 13.5 in a b4, comes off after 8m + warmup about 140-145.
running 81/28 on a 13.5 in a t4, comes off around 140-145 in 8m + warmup
all this around 90-95 deg outside
Jake S is offline
Old 07-25-2011 | 04:16 PM
  #4312
8T's Avatar
8T
Hey guy's, i just started racing my T4.1 with a Tekin rs and a 17.5 with boost. My gearing right now is 20/87 and the motor seems pretty cool after a 7 min main. I was thinking of going to a 21 or 22 pinion, but a few have suggested going to something like 26/75. What do ya think?
Side note, it was my first race with this truck. Normaly i race expert truggy. I finished 4th in the main started last(12 in the class) The reason i started last was because i let my friend(expert nitro buggy driver) race the last qualifer instead of me, and he set tq! It wasn't right to use his tq so i told the race director and that i would start last. It was a blast!
tia
8T is offline
Old 07-25-2011 | 04:27 PM
  #4313
Asharus's Avatar
No boost/timing
Asharus is offline
Old 07-25-2011 | 04:35 PM
  #4314
Ok, I'm curious how everyone determines when and how much boost to use? For instance, does everyone find the correct FDR (Final Drive Ratio) for their specific vehichle and track they are racing on first, then add boost? Interested in everyone's thoughts
Old 07-25-2011 | 04:42 PM
  #4315
No boost/timing
Do you prefer running all your vehicles without boost? if so why?
Old 07-25-2011 | 04:47 PM
  #4316
Asharus's Avatar
Most 17.5 SC (if not all) in my area have a no timing/boost rule.
Asharus is offline
Old 07-25-2011 | 04:50 PM
  #4317
Matt Trimmings's Avatar
Originally Posted by Wild Cherry
Matt , what body fits your extended chassis ?
I just got a bulldog. It seems like it should fit fine, I haven't mounted it yet. I am also going to try a punisher, that's what bk was running on his before worlds.
Matt Trimmings is offline
Old 07-25-2011 | 04:51 PM
  #4318
Well that makes sense then...lol. When you do use boost how do determne how much and rpm ranges? and do you that after the basic FDR?
Old 07-25-2011 | 06:26 PM
  #4319
Asharus's Avatar
I recently boosted my B4.1 to 30 degrees using the same gearing I was using without boost, because it was temping pretty low 130-140. Now it temps at 150ish, just the way I like it.
Asharus is offline
Old 07-25-2011 | 07:06 PM
  #4320
idrummerboy13's Avatar
Also remeber 120 degrees can feel very hot to the touch, I thought my esc and moter was ganna blow but it was 140 degrees. Just a pointer,to dirtracer.
idrummerboy13 is offline
