RC10B4.1 FT/WC
Old 09-03-2011 | 01:11 PM
  #5641
bilster44's Avatar
If someone wants to buy a whole kit for the diff of their 4.1, it is made by MIP and it is an "SC10" ball diff kit: MIP 9130 Ball Diff Kit SC10.
bilster44 is offline
Old 09-03-2011 | 02:38 PM
  #5642
bilster44's Avatar
I just took a look at the ASC9853 that Matt posted...I'd rather have that one myself beings the A team sells it and all. Only difference is the MIP one has a black diff gear.
Old 09-03-2011 | 02:44 PM
  #5643
mellow's Avatar
Originally Posted by Matt Trimmings
You would need to buy the bodies and seal kit, you might be better off getting the kits because they also come with the titanium nitride coated shock shafts. Fronts are .89 and the rears are 1.18.
The fronts are actually .80" and the rears are 1.02"
mellow is offline
Old 09-03-2011 | 02:48 PM
  #5644
Matt Trimmings's Avatar
I was referring to the bodies...but yes, those are the shaft sizes.
Matt Trimmings is offline
Old 09-03-2011 | 03:06 PM
  #5645
mellow's Avatar
Oops, misread that. On a side note. Here's my freshly painted Finnisher. Not a fan of most cab forward designs, but this thing is pretty sweet.
mellow is offline
Old 09-03-2011 | 05:32 PM
  #5646
idrummerboy13's Avatar
Default selling my b4.1
Use the for sale forum for this type of post.
Thank you
Last edited by Kraig; 09-04-2011 at 08:59 AM. Reason: Post your sales thread in the proper section.
idrummerboy13 is offline
Old 09-03-2011 | 07:08 PM
  #5647
RCmayor's Avatar
Search McMaster.com for part number 28685A47. I think this would be perfect for making the cut on a T4 chassis. You could even do an angled cut pointed to the front to make for more glue area. You would just mount the bit in a mill or even a drill press then cut away. I would probably mount the chassis to a piece of wood though so it would stay flat.
RCmayor is offline
Old 09-04-2011 | 08:20 PM
  #5648
Jake S's Avatar
http://www.slide.com/r/gOHRybBa3j81_...t_embedded_url
is how i went about it.
Jake S is offline
Old 09-04-2011 | 09:15 PM
  #5649
Wild Cherry's Avatar
Tech Legend
So much work to cut a straight line ....
I cut one with a powered miter saw , achieve a perfect cut real easy like....
Took me less than one minute to cut , had it all glued together & ready to run in 5 minutes ....
Wild Cherry is offline
Old 09-04-2011 | 09:16 PM
  #5650
mellow's Avatar
Sure you did..
mellow is offline
Old 09-04-2011 | 09:19 PM
  #5651
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
What kind of blade did you use?
SpraydbySprague is offline
Old 09-04-2011 | 09:20 PM
  #5652
Tech Legend
Originally Posted by mellow
Sure you did..
You don't believe ?
A miter saw is probably the perfect tool for the job , no clamps , less than 1 minute to cut & no need to even sand much at all ...
Not sure which blade , all the printing on the
blade is worn off, blade design is for cutting molding ....
  #5653
mellow's Avatar
Use a fine tooth blade to get the best cut. Table saw works great.
mellow is offline
Old 09-04-2011 | 09:23 PM
  #5654
mellow's Avatar
You don't believe ?
The part I don't believe.
mellow is offline
Old 09-04-2011 | 09:30 PM
  #5655
Tech Legend
How long do you think tire glue takes to dry ?
Also use accelerator and yes less than 5 min to glue . Not anymore difficult to glue than a tire ...
