RC10B4.1 FT/WC
Old 02-13-2013 | 08:37 PM
  #28126
zipperfoot is offline
Old 02-14-2013 | 05:40 PM
  #28127
5th wheel's Avatar
Originally Posted by 5th wheel
I run on a smooth indoor track hard clay. What can I expect from the b4.1 if I shave the u brace and use the c hubs some big jumps and small ones running 17.5..its a little more than a medium size track.we use a bar codes type tires. Kind of still new at this stuff. Thanks for your help.
Any help here?
5th wheel is offline
Old 02-14-2013 | 06:26 PM
  #28128
Venom1836's Avatar
What track and it never hurts to try them.
What is your car lacking in?
Venom1836 is offline
Old 02-14-2013 | 06:29 PM
  #28129
lilws6's Avatar
WHOO tomarrow will be my first race with the b4 i'll be running both my buggy and my truck hopefully i won't get to mixed up switching between the two. I'll have to report back tomarrow night or saturday on how it drove.
lilws6 is offline
Old 02-14-2013 | 06:42 PM
  #28130
5th wheel's Avatar
Space coast rc in cocoa. Needs to be more stable in corners
Old 02-14-2013 | 06:49 PM
  #28131
sneako's Avatar
Default 0 degree hubs
I use the stock U brace so I can't say what that mod will do.
I just changed over to the B44 plastic hubs (#9730) and saw a big change in how my car handled in and out of the corners. I run at a track similar to the one you described in your other post. I also run a 17.5 with Barcodes.
My buggy was pretty hooked up the other day after making that change. I plan on swapping to 30 degree caster blocks next to see how that changes the steering.
I use the Brent Thielke Club Racing Indoor Clay set-up sheet with very few changes.
sneako is offline
Old 02-14-2013 | 07:56 PM
  #28132
3srcracing's Avatar
So I sent my car home with one of my friends for he can tune it up for it's good for this "big" race I'm going to..
He replaced the following parts:
Arms, Top Plate, T Plate, Chassis, Diff, added Ballast weight, rebuilt shocks
I will report back on how my car feels now.
3srcracing is offline
Old 02-15-2013 | 07:50 AM
  #28133
What are the ideal battery packs for the B4.1WC? I'm not hip on all the 2s, 3s lingo etc. also is it ideal to have short and long packs for tuning?
ForwardBite is offline
Old 02-15-2013 | 08:11 AM
  #28134
Wildcat1971's Avatar
wolf packs are nice for mod, shorties for stock. 2s only for racing
Wildcat1971 is offline
Old 02-15-2013 | 08:57 AM
  #28135
Thanks!
Old 02-15-2013 | 10:20 AM
  #28136
Kave, everyone here has given you several options. I see you decided on the trackstar 8.5 motor, fine. Since you dont mind the Hobbyking products, why not get their esc. I will link this for you again. If $35 is too much, then I am sorry.
http://www.hobbyking.com/hobbyking/s...nsorless_.html
Also
I am not sure if a 60amp esc will work in a b4 with an 8.5. My guess is probably, but is more than likely an "it depends"
or maybe this one
http://www.hobbyking.com/hobbyking/s..._10th_ESC.html
Thanks wildcat
Sorry for all my bullshit. Your recommendation was perfect but after reading some on the esc and contact HK support seems that there is an issues with programming card for it at the moment. So I guess I'll go on a combo
http://www.hobbyking.com/hobbyking/s...000KV_60A.html
The only thing that bothers me that the esc is 60a and not 120.
kavee is offline
  #28137
With the shorty what config have you found to have the best effect on the handling? small foam front then battery then large foam in rear, etc ?
jstump is offline
Old 02-15-2013 | 10:47 AM
  #28138
Waflet's Avatar
Hideeho
Most folks seem to set the back of the lip even with the front of the u-brace. I set mine aprox 7mm forward from that. Then again I also run a t4.1 chassis that is about 7mm longer
Waflet is offline
Old 02-15-2013 | 10:52 AM
  #28139
Originally Posted by kavee
Thanks wildcat
I am sure that combo will be fine
Old 02-15-2013 | 03:59 PM
  #28140
snowman_evil's Avatar
Has anyone tried the Losi BK Bar rear tires or the Losi Taper Pin front tires?
Any feedback, looking into getting some but just seeing if anyone has tried them and their thoughts on them.
snowman_evil is offline
