RC10B4.1 FT/WC
I'm using the same servo ... from memory it was no spacer and a futaba F servo arm... havent had an issue with it
Use the Futaba servo horn for the Savox servo.
Hi guy
I have installed a Savox servo in my b4.1 RTR and see a great improvement in steering, also using futaba 4pl transmiter. But in order to compete the motor and esc are still weak, can't over the doubles on the track...
Any recommendation for good motor (7.5) and esc for this car? (not too expansive)
Eran
ae b4.1
Tamiya trf 502
Eran
ae b4.1
Tamiya trf 502
Guys
I believe I decided to go on 8.5T sensored motor - trackStar 4620kv.
http://www.hobbyking.com/hobbyking/s...or_4620KV.html
But I still don't know which esc will be compatible?
(combos are to expansive)
Are all 1:10 motor size are the same and will fit the b4.1 RTR and replace the original motor xp reedy 3300kv?
Can you please advice on both questions.
Eran
ae b4.1
Tamiya trf 502, LRP, futaba 4pl
Guys
Eran
ae b4.1
Eran
ae b4.1
I did a search and found the post from WC about the Losi kit. Is this a fix for the BB shocks only?
Will this solve the problem or do I need new caps? What Associated non-bleeder caps work - are the threads the same from other AE kits? Does the aluminum set #1598 fit?
Thanks.
Hi,
Any of the small bore off-road shock caps will fit.
(IE non bleeder plastic caps.)
What you can do is re-make the threads in the cap for the bleeder screw with super-glue.
You need the bleed screw to nip up tight to stop air getting in.
MiCk B. :-)
MiCk B. :-)
thanks
i thought on something cheaper, 67$ is twice price than the Motor.
do you know if all 1:10 scale motor are same size?
All 540 can motors have the same dimensions and bolt holes and will replace your stock 3300kv....and if you dont want to spend 67anything on a bh esc then dont replace your stock speedo...if your cheap motor doesnt have a sensor wire just run your stock esc...if it does have a sensor wire get the brushless hobbies esc...you cannot find a more reliable esc for under 70 bucks....
http://www.hobbyking.com/hobbyking/s...nsorless_.html
Also
I am not sure if a 60amp esc will work in a b4 with an 8.5. My guess is probably, but is more than likely an "it depends"
or maybe this one
http://www.hobbyking.com/hobbyking/s..._10th_ESC.html
