RC10B4.1 FT/WC
Old 09-16-2012 | 09:04 AM
  #20596
IRM616's Avatar
Originally Posted by EricJ
You do know that stainless bends easier than common titanium screws, which in turn bend much, much, much easier than your kit screws, right? They also weigh more than both.
Sounds like a lose lose situation
IRM616 is offline
  #20597
ilanstylz's Avatar
Originally Posted by IRM616
Waddup I how are? My b4.1 is no longer stock...running 8.5 redline. Stock is not popular at my Vegas at all. Howvr ur rides?
Sup bro, my cars are doing great except the dest210r which I still can't figure out a good setup for it so I may be trading it very soon....... When's the next time your heading to WCRC??????
ilanstylz is offline
Old 09-16-2012 | 09:08 AM
  #20598
Wildcat1971's Avatar
+1 I have tried several stainless screws. they tend to be softer. They are just a look thing. The kit screws seem pretty strong.
Wildcat1971 is offline
Old 09-16-2012 | 09:18 AM
  #20599
jbrooks39's Avatar
Default Motor Guard?
Are there any motor guards available that provide more protection for our brushless motors? E.G., one that extends further to the left, when looking at the rear of the buggy, to protect the sensor cable area?
Thanks,
JB
jbrooks39 is offline
Old 09-16-2012 | 09:20 AM
  #20600
Wild Cherry's Avatar
Tech Legend
Thanks,
JB
Best you can do is zipp tie the sensor wire to the motor leads.
Wild Cherry is offline
Old 09-16-2012 | 09:23 AM
  #20601
jbrooks39's Avatar
Definitely do that; it is well protected (to a point). I was just wondering if there was a bigger motor guard. The TLR 22 seems to have a very generous one and I was hoping there was one in a similar design for the B4 family.
JB
Old 09-16-2012 | 09:32 AM
  #20602
ryanpatrickgore's Avatar
Default hubs v2.0
k earlier this week i posted my hubs that I took the anodizing off of. and ley looked crappy.
i polished em up and added new c's. now i like em hope u do to.
Attached Thumbnails RC10B4.1 FT/WC-hubs2.0.jpg
ryanpatrickgore is offline
Old 09-16-2012 | 09:45 AM
  #20603
Originally Posted by RC10Nick
I don't even know what my rear toe is right now. I've got the original b4 rear arm mount (the one with the shims for anti squat) and the plastic b44 hubs (#9730). I really cant find anything on either of those.
Any help would be appreciated. thanks.
Unmarked rear arm mounts/blocks are 3 degrees. All FT kits should come with a range of these from 2.5-4 with 1 and 2 degree shims.
Outboard toe done with an aluminum rear hub is somewhat different, as it allows your wheelbase to stay the same while running more toe.
You use stainless for corrosion resistance, not strength.
Any Ti hardware you can afford is only marginally less prone to bending than stainless, too. Ti is good for some situations, but none I can think of that occur in RC vehicles that would not be better served with a strong steel screw.
None make it that far. Zip tie the sensor cable to a motor wire to protect it more. The SC10 motor guard provides marginally more protection on the left, but not enough to protect your sensor wire.
EricJ is offline
Old 09-16-2012 | 09:59 AM
  #20604
Tech Legend
JB
You can tab a little Shoe Goo over the plug & wire..
Will be very strong and never come loose ...
Old 09-16-2012 | 10:10 AM
  #20605
IRM616's Avatar
Prob around oct 12th. My t4 with Fantom rocks. Ion4
IRM616 is offline
Old 09-16-2012 | 11:29 AM
  #20606
Plexabit's Avatar
Originally Posted by vw addict
There are better deals out there in the classifieds, keep looking. I got my 4.1 ft with a Tekin RS and Redline 8.5 for $200.
'mazing, man. I'll keep lookin.
Plexabit is offline
Old 09-16-2012 | 11:47 AM
  #20607
I haven't seen many of them around, but the ones I have seen haven't really impressed me too much. What problems are you having with it?
jpcopeland1 is offline
Old 09-16-2012 | 11:56 AM
  #20608
I've seen way too many people break off shock mounting screws that were stainless. For looks, yeah they are neat.... Functionality big fail for shock mounting. I can see them being used for bulkheads, servo mounts, But a big no no on anything to do with shocks since it's the most stressed areas of the car.
  #20609
Default durability
Originally Posted by UN4RACING
You definitely have a sweet ride there sir. Thanx for sharing the mod. Has it been durable. I was going to try that some time ago when I saw it done in the for sale thread on a B44.1. I was worried about cutting out some of the bracing.? the Nuts are a plus on yours.....
The wing mount itself has been very durable, my driving has tested its limits! The only issue is the wing doesn't have the play to move around during crash so it takes more abuse. My reposnse to this has been the LMR Electra wing. Its much more durable than any other wing on the market.
associatevalley is offline
Old 09-16-2012 | 12:02 PM
  #20610
I can't find that lmr wing anywhere in the us.
Where did you get it?
