RC10B4.1 FT/WC
If you have more motor than needed (example 6.5 T on a short track) is it better to gear so the buggy has less top in or adjust the maximum output to the motor and run normal gearing? I am thinking if you gear for less top in then you would have too much bottom end. I guess then you would just adjust the slipper for a smoother take off?
I know....just buy the right turn motor. I already have too many motors and really don't want to buy any more.
Can also use ARC throttle or to smooth the power.
Note :
Reducing the throttle ARC or EPA more than 25% will remove some bottom end power as well.....
Thanks, I have a M11 radio but haven't figured out all the things this radio can do. One questionI do have is where do you set your ESC settings on everything if your radio is capable of making these changes. I am assuming nuetral or 0% for most, like braking, throttle control, etc.
Just ordered a b4.1 wc I had one before when I ran carpet but know I run dirt. What motor should I get a closed can or vented I'm thinking closed and what brand it will be a 7.5 or 8.5. Thank you
i would suggest an Orion Pro Race or Reedy motor..the turn would be depending on your track size..but 8.5 is a good motor on any sized track.
Thanks again
i would run stock buggy,learn how to drive it and get comfortable wheeling it around and learn how it reacts to everything,when you think its time move up to mod,I've been running stock for a while just haven't been able to race on a consistent basis,my buddy has a 7.5 I'm thinking about trying but right now with my setup and gearing for blinky 17.5 my car is damn fast and its on rails.took 1st in stock buggy fri night
Does anyone run 12mm hex in the rear only, to prevent stripping out the slot on the stock wheel? Im going to order wheels tomorrow and thought about buying a hex setup for the rear but buy stock syle wheels for the front.
Any pros/cons to setting it up this way or should I just buy slotted rear wheels?
