RC10B4.1 FT/WC
Old 03-04-2012 | 10:18 AM
  #12376
Originally Posted by JakeC351
I'm running koyosho whites in front and golds in the rear. And love them used to run Losi orange in the front and yellows in the rear and they felt really good but koyoshos even feel better!
That's what Cavalieri was running on the track that i run on. Was just trying to get a lil more input. I'll run the same springs then. Thanks
Jaymo13 is offline
Old 03-04-2012 | 10:19 AM
  #12377
Wild Cherry's Avatar
Tech Legend
Originally Posted by turtletrax
Could somebody help me with a setup for tight high bite clay(run slicks for tires) Running the stock worlds setup now and it is pushing incredibly bad. I have the battery all way forward and no ballast in the rear. Also what should these weigh rtr?
Put the ballast back in by
the transmission , will make the car steer way more ...
*use the team weight , or up to 21 gram for the most steering ..
Wild Cherry is offline
Old 03-04-2012 | 10:21 AM
  #12378
Matt Trimmings's Avatar
http://www.petitrc.com/reglages/BuggyBigBoreSpring.pdf
here is the big bore spring chart.
Matt Trimmings is offline
Old 03-04-2012 | 11:50 AM
  #12379
Thanks for both of those spring charts guys!
adam lancia is offline
Old 03-04-2012 | 12:04 PM
  #12380
jf+'s Avatar
jf+
What tires are you using? Where are your shock mount locations? When you press the front, then rear all the way down, do they rebound at exactly the same rate? Good starting points to check...
jf+ is offline
Old 03-04-2012 | 02:20 PM
  #12381
B44's Avatar
B44
On the team drivers setup they say to run b44 rear arms on the b4,what would that part number be. I found #9583 carbon arm for b4.and I found #9764 which is the same arm for both cars.
B44 is offline
Old 03-04-2012 | 02:21 PM
  #12382
9764 is the b44 rear arm, 9582 is the standard b4.1 rear arm
Old 03-04-2012 | 03:53 PM
  #12383
B44's Avatar
B44
Thank You.
B44 is offline
Old 03-04-2012 | 04:01 PM
  #12384
so what is the difference between the arms???
dan-o is offline
Old 03-04-2012 | 04:03 PM
  #12385
9582 is softest
9764 is medium
9583 is stiffest
Can use as a tuning aid in high/low bite conditions
Old 03-04-2012 | 04:17 PM
  #12386
CraigMBA's Avatar
The problem with that chart is the word in front of (lb/in.), that being "theoretical". The mfg's ratings are only useful if you stay in one mfg's product.
In short, that chart is wrong.
CraigMBA is offline
Old 03-04-2012 | 04:19 PM
  #12387
Well, that's the only thing available. Until manufacturers test their springs the exact same way nothing is going to change.
Old 03-04-2012 | 04:59 PM
  #12388
Hi guys and gals...maybe
So,got my B4.1 working allright,was looking for some stick on weight last race day...But,stick ons look so cheap,and nasty...even with sharpie marker paint job...
A mate showed me these..... Even match the current trend on gold turnbuckles.
Its a pity it comes with the big 50 gram block,im only using the 4 and 6 gram squares...look awesome mounted,uber neat.
Maybe ask some of the racers at yor track if they have the kit,and arent using the square weights...
Just requires a drill,and a 3mm tap...the tap isnt required,i had 1 loaded,so i used it.
Ignore the stick on,i forgot to pull it off before the pics...
http://www.tlracing.com/Products/Def...ProdID=TLR4151
Also,do you think using the alloy screws on the front axle to secure the wheel is tempting fate,or will it be fine...i race mod,and still crash occasionally...I went to the 4/40 screws,the little ones strip to easy
Cheers....and +1 on AE loosing the blue ano.....none of it matches,it looks nasty...im voting gunmetal grey,with gold detailing,shock shafts,turnbuckles,few alloy bits here and there...no more shoddy blue
Attached Thumbnails RC10B4.1 FT/WC-003.jpg   RC10B4.1 FT/WC-002.jpg   RC10B4.1 FT/WC-001.jpg   RC10B4.1 FT/WC-004.jpg
Peli is offline
Old 03-04-2012 | 05:07 PM
  #12389
CraigMBA's Avatar
No offense, but what good is it if you know it's wrong? There is an alternative, but it requires some work:
Users can rate their own springs. Google is chock full of how to articles on how to calculate wheel rate.
That's how I figured out the chart is no good. And how I figured out a certain set of springs I received were actually two different springs (they were both marked the same, and in the same factory sealed package). Upon further inspection, the wire sizes were substantially different.
I can't believe I'm the only one who got "lucky". I can believe I'm the only one who caught it because I was looking.
CraigMBA is offline
Old 03-04-2012 | 06:09 PM
  #12390
Here's what you need to know (IMO)
AE Green rear 1.9
AE brown front 2.8
KY gold rear 2.5
KY white front 3.72
Losi Yellow rear 2.0
Losi orange front 2.9
Other Losi options
Losi White rear 1.8
Losi Pink rear 2.3
Losi Silver front 3.2
And now my head hurts....
Bob Barry is offline
