RC10B4.1 FT/WC
Old 03-01-2012 | 03:22 PM
  #12256
brent701's Avatar
Originally Posted by STUBYSLAP31
it will be a vyper 13.5
Viper's gear different than most other 13.5T's due to the lower Kv rating
my 13.5 is geared at 25/84 in my SC10 and 17.5T is 32(33)/72 in my B4.1
try 33//75 in your Buggy with the 13.5
Check temp after 2 mins than again at 5
My motor comes off at 140 after 7 mins
brent701 is offline
Old 03-01-2012 | 03:28 PM
  #12257
Timmahhh's Avatar
Originally Posted by t4ftracer
the Avid ones are beautiful. I have two sets, like brand new. Selling both together for $25 shipped if anyone is interested.
Deal! Pmed
Timmahhh is offline
Old 03-01-2012 | 04:25 PM
  #12258
onefast8's Avatar
Originally Posted by Matt Trimmings
Which 13.5? With the Reedy im running 72/32 with no timing in the speedo. With timing I was running 72/29.
Matt, What motor timing are you running that gearing at?
onefast8 is offline
Old 03-01-2012 | 04:29 PM
  #12259
-WHEELMAN-'s Avatar
Originally Posted by Jmuck69
Nothing but good! Maifield is running them and it was designed by a former AE engineer. Try AVID bearings as well, the best in the industry.
Agreed!!! AVID for the win!!!!
-WHEELMAN- is offline
Old 03-01-2012 | 04:37 PM
  #12260
IRM616's Avatar
thanks
IRM616 is offline
Old 03-01-2012 | 04:41 PM
  #12261
idrummerboy13's Avatar
30 75 for me full timing is so fast and runs no more than 120. The mod guys ask if i put in a 10.5
To run in with less torque bc these have more torque then the other motors, gear up, i going to try 33 75 and make it somewhat hot. 140 after 10 min is my goal ...i put a 17.5 in my car, feels dead.
idrummerboy13 is offline
Old 03-01-2012 | 05:12 PM
  #12262
beedee's Avatar
Originally Posted by jirish617
For those of you running velcro on your bodies, have any of you just eliminated the rear tab that normally goes over the pin for the body clip? A buddy of mine bought a used b4.1 and they had it cut clean in the back with no tab, and in my eyes seems it would work well. I'm still using body clips but eventually that tab starts to crack off, my dad has velcro but still has the tab with no clip and it seems to slowly be cracking a bit too. I have a body being painted by a local guy and I plan to actually take care of it and thought about removing the tab to help it last a tad bit longer, any one else do this?
i dremelled the body mount nub off the back, and kept the tab.
beedee is offline
Old 03-01-2012 | 06:20 PM
  #12263
Kurt04's Avatar
Will you separate? PM me.
Kurt04 is offline
Old 03-01-2012 | 08:29 PM
  #12264
jbrooks39's Avatar
Default Hex Conversions?
Are the hex conversions for the B4.1 (front and/or rear) really worth it?
Trying to sort-out need items versus want items for my B4.1 build and the only advantage I can see right now is that you "capture" the roll pin on the rear so you cannot lose it (assuming you are using the clamp-on style hex piece from JConcepts or Proline).
Thanks in advance.
JB
jbrooks39 is offline
Old 03-01-2012 | 08:32 PM
  #12265
t4ftracer's Avatar
The avid bellcranks are sold. Thanks
t4ftracer is offline
Old 03-01-2012 | 08:33 PM
  #12266
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Thanks in advance.
JB
Does anybody ever really have roll pins fall out? They squeeze in there pretty tight. Not as tight as they did back in the day, but they're in there.
T-BirdJunkie is offline
Old 03-01-2012 | 08:46 PM
  #12267
has anyone tried the losi 10 T shock bottoms for the bb setup?
controlledchaos is offline
Old 03-01-2012 | 09:04 PM
  #12268
Timmahhh's Avatar
The rear hexes are nice... and if a nut isn't fully tight they are less likely to spin on the hex than a pin. The fronts were really convenient, but my c clips gave way and caused issues (had the nut too tight trying to avoid losing a front wheel like the losis are prone to) On a practice lap, the c clip bound the axle when it was rubbing the kingpin, and by the end of the race a bearing had exploded. I'm back to pin fronts since the convenience isn't worth a dnf.
Timmahhh is offline
Old 03-01-2012 | 09:11 PM
  #12269
onefast8's Avatar
No. Looking at my scte eyelets though... they are large. My 22 springs will be here sat, Ill let you know.
onefast8 is offline
Old 03-01-2012 | 09:15 PM
  #12270
I just tried the losi 10 T bottoms tonight there pretty tight. You have to work them on but other then that seems like it worked.
