RC10B4.1 FT/WC
Old 02-28-2012 | 10:59 AM
  #12106
mxracer458's Avatar
Originally Posted by ittjv
I think so - TLR5173 (Org) and TLR5174 (Slvr) for the front.
I haven't added any weight yet, so that might help.
i know when i ran my shorty yellow/red that the front spring was almost all the way to the top,when i ran the full size lipo it was down 2-3 mm.
mxracer458 is offline
Old 02-28-2012 | 11:17 AM
  #12107
Matt Trimmings's Avatar
Originally Posted by makaluch
What position are you guys using for the hub carrier on the front arms of a +8 WC?
Mine only came with the big single spacer per side so my only sensible option was moving the carrier forward. I'll grab more spacers if the center position is standard. I can't find any clear information on carrier placement or it's use as a tuning option.
That is not a tuning option as far as forward / back. The carrier is meant to be ran in the back position (spacer in front) when running inline axles to maintain the correct wheelbase.
Matt Trimmings is offline
Old 02-28-2012 | 11:32 AM
  #12108
Default Springs
I am running Kyosho springs. White in front and gold in rear with Losi cups and the traxxas collars. I was a big improvement over the stock setup. I then put my Durango dex210 shocks on and the car was dialed. I am going to order another set of front shock bodies from durango to put in rear to correct the droop. This buggy is going to be so good when AE comes out with the Big Bores!
mhuse6969 is offline
Old 02-28-2012 | 11:44 AM
  #12109
bilster44's Avatar
The big spacer goes behind the caster block in the front arms when you are using the "stock" trailing steering spindles.
bilster44 is offline
Old 02-28-2012 | 11:58 AM
  #12110
Originally Posted by nismomike
What lipo are you using when you check your ride height?
Reedy 40c+ regular length w/ the thicker spacer in the front position.
ittjv is offline
Old 02-28-2012 | 12:27 PM
  #12111
Found this picture on the Jconcepts blog page. Do you see what i see???
deftones4012 is offline
Old 02-28-2012 | 12:29 PM
  #12112
SkarTisu's Avatar
One thing that zapped me when I converted was that I used RPM spring collars and didn't force them over the bottom of the AE threaded collars. This used up some of the real estate needed to get the ride height down far enough.
SkarTisu is offline
Old 02-28-2012 | 12:30 PM
  #12113
SkarTisu's Avatar
Hartson's clear rear axle nuts?
SkarTisu is offline
Old 02-28-2012 | 12:36 PM
  #12114
Big Bores!!!,, bring them on...
indybobb is offline
Old 02-28-2012 | 12:38 PM
  #12115
Big bore shocks?
htrd03 is offline
Old 02-28-2012 | 12:46 PM
  #12116
onefast8's Avatar
Yeah, I mean REALLY who uses WD40 anymore!
onefast8 is offline
Old 02-28-2012 | 12:55 PM
  #12117
Thats what i was seeing. Wonder if its some sort of quick change wheel? Maybe thats why there are no ae rear hex wheels avalible? Lol
Old 02-28-2012 | 12:59 PM
  #12118
davidfast's Avatar
Ha!
davidfast is offline
Old 02-28-2012 | 01:02 PM
  #12119
ME!
best way to clean your car
Bob Barry is offline
Old 02-28-2012 | 01:03 PM
  #12120
njnewc's Avatar
Too Funny... I laughed out loud, my boss is wondering what the hell is going on... LOL...
njnewc is offline
