RC10B4.1 FT/WC
Hi Guys,
For those of you running Losi springs; it seems the lowest I can get the front ride height to is 25mm. I have the collars adjusted all the way up and I’m using the traxxas collars over the stock threaded collars and Losi spring cups. Am I doing something wrong or is this par for the course?
Thanks,
Jose
Thanks,
Jose
Brent just text me and said all i needed to convert was a B4.1 W.E. , losi spring cups, traxxas spring retainers, and a cucumber. I'm just not sure about one thing and that is, what are the traxxas spring retainers for? He said the cucumber has something to do with anti-squat lol.
Hi Guys,
Thanks,
Jose
Thanks,
Jose
http://www.amainhobbies.com/product_...Shock-Mounts-4
Put 2 washers so the shock itself extends away from the shock tower, problem solved no robbing, ride heigh at 24mm.
it was the only place that had them during my search
edit: i saw a set on ebay i think.
The notch in the middle. So it goes Bearing, C-Clip Bearing http://www.teamassociated.com/pictur...9881.ps_md.jpg
What position are you guys using for the hub carrier on the front arms of a +8 WC?
Mine only came with the big single spacer per side so my only sensible option was moving the carrier forward. I'll grab more spacers if the center position is standard. I can't find any clear information on carrier placement or it's use as a tuning option.
