RC10B4.1 FT/WC
So decided that since I was running the Losi BB springs and such lets go all out 22 style. HA. Took a T4 chassis and cut it down to a narrower version. With center carbon bracing. Its cut to a +10 mm over stock. Added a esc shelf that doubles as a battery hold down and there you have it. A 22 Bulldog body fits it perfect too.
Been raining for a couple weeks here so havent got to try the thing out at track yet.
O well. At least if it sucks, so what I'll put the +8 stocker back on. The track I race on is outdoors, very bumpy and dusty/loam so I dont think it'll suck.
Looks cool though :P I'm betting it's dialed on a low bite track but I wouldn't take it onto a high bite one with all the flex. Let us know how that bad boy works
Yeah Barry, the track I'm at is no where near High Bite.
leave the 81 on it and throw a 25 pinion on. run a few laps and check temp. I would also probably run some boost on this track because of how big it is....have some of the speed come on later so you still keep the smoothness out of the turns but on those big straight sections it has some kick.
m3 2.2 rears, was 28-29. seconds I got me groove fronts and goosebumps an double dees.I hope they work.
The Schuur is coming on strong at our track, WCRC. It comes with the high torque rotor, has great low end and strong pull on top. Check out the Schuur thread for more info.
Edit: I do see some velcro in the front
Going to try the 22 Finnisher next. It looks sick.
A bit delayed, but:
While ball cups are obviously up for debate, the small RPM front bumper for the B4 should be an AE stock part.. it's beefy as hell and has saved my bacon dozens of times. Offers way better protection, lasts way longer, it's more secure, and it's five bucks. Absolutely recommend it for anybody, even if you're good. Too bad they don't make a motor guard..
A bit delayed, but:
http://www.youtube.com/watch?v=PFzJNQ9PAHo this is my track where we are race 1/10 buggy and truck for the first time , i am the big guy in the video too, but i dont think ur chassis will last here????
You also will benefit by having a set of tires, like M3 holeshots, with std foam. They will be softer and give you more bite. Just remember, when the bite comes up, they could make your lap times slower because you will 'bind' in the turns. That's when you switch to the closed cell. I'm also gonna assume that 8th scales are gonna blow that track out so you may have to run those goosebumps LOL
