RC10B4.1 FT/WC
Old 02-16-2012 | 09:19 AM
  #11506
Originally Posted by Littlejohn Dsgn
Couple questions for you guys, I am getting my FTB4.1 today (the post office had lost the box for over a week and a half)
I am going to be running a grear diff in it (got one in my T4.1 as well) what fluids are you guys going with for a med/high traction tight indoor track? Local guys are running 3k in their trucks.
Now onto batteries will a 30c rating pack be enough for stock 17.5? Plan to go with GensAce I have had great luck with them in my 1/8ths as well. I am not even close to the fast guy at my track .... still working on driving skills so keep that in mind.
One more thing do you guys know what size bearings are used in the front wheels for the B4.1 and T4.1? I got a bearing kit from Avid and did not look to see if those are included or not Either way I would like to order up a few extras to have.
I run the gens ace 40c 5000mah packs in all my cars with great results. I too am by no means the fastest guy either but my car can keep up fine. as you mentioned you are still working on your driving so these batteries will suit you fine until you get to that next level where it may make a difference. for the $ you cant go wrong.
ritojr is offline
Old 02-16-2012 | 09:24 AM
  #11507
bilster44's Avatar
Originally Posted by JoshCorti11
Hey guys ran my b4.1 with the bb springs for the first time yesterday and noticed my car did not react as well over the bumps as with the stock springs I am running silver in front and yellow in back also running 23 mm ride height and 30wt shock oil in front and 27.5 in the rear, piston 2 in front and 1 in rear
Ah Hah ! Try #2 pistons in the rear and 24mm ride height all the way around, you WILL notice a difference with the big bore springs then.
bilster44 is offline
Old 02-16-2012 | 09:25 AM
  #11508
my testing brought me to the conclusion that the stock springs make the car feel more precise/darty. Maybe you are just used to that feel and it suits you better. I would say give the BB springs 2 weekends and then try the stock springs again and see if you are better with one or the other. for me, I was more consistant with BB but quicker hot lap with stock. So I chose the BB (and they look cooler ). It really comes down to you and what you like better.
Bob Barry is offline
Old 02-16-2012 | 09:26 AM
  #11509
DOH!!!!!! guess I should have caught that too
Old 02-16-2012 | 09:27 AM
  #11510
lol I have the 30C version of those packs. I'm not lacking for power either. Although I don't run in a spec or blinky class.
Old 02-16-2012 | 10:26 AM
  #11511
jf+'s Avatar
jf+
I really like my two Turnigy hardcase lipos. One of them is a 65C 6000mAh nano-tech, the other's a 20C 5000mAh regular. They both run the stock Reedy 3300kV (RTR) just great. No heat, no swelling, excellent run time, great reviews overall, and the price is
The 65C was about $50 shipped, the 20C was $25 shipped
You can obviously spend more for another name, but these have been tried by many folks with very good results.
jf+ is offline
Old 02-16-2012 | 12:11 PM
  #11512
EvanAZ's Avatar
Default rear arms
I saw on the a couple set up sheets that some are using B44 rear arms is there a big difference in these over the B4?
EvanAZ is offline
Old 02-16-2012 | 12:41 PM
  #11513
Tyler Keel's Avatar
Different compound. I believe the B44 rear arms are a softer plastic, allows more flex. I believe it only makes a "noticable" difference on high bite surfaces. I'm using them in combo with the B44 stock rear hubs (0*) and I love the way it drives.
Tyler Keel is offline
Old 02-16-2012 | 12:56 PM
  #11514
Jake S's Avatar
think it has been said that b4 is the most stiff, followed by b44 arms, followed by b4.1 arms.
Jake S is offline
Old 02-16-2012 | 01:15 PM
  #11515
What is the peoples thoughts on sb kyosho ,dont like ae springs they rub and cant find bb kyosho and no fitting probs ( front tower ) what is the hot set up pr was the hot set up ? Thnx
blingy is offline
Old 02-16-2012 | 01:26 PM
  #11516
skengines's Avatar
anyone running K springs?
skengines is offline
Old 02-16-2012 | 01:42 PM
  #11517
Losi's finance dept. must be like "How da hell did our 22 springs revenue spike 300%?!?"
GuiltyByAssoc is offline
Old 02-16-2012 | 03:09 PM
  #11518
Just1More's Avatar
B4 Carbon rear arms-Most stiff and most likely to break
B44 rear arms-Between plastic and carbon, some flex
B4 standard rear arms-The most flex, can give traction on loose tracks, less likely to break than the rest
Just1More is offline
Old 02-16-2012 | 03:33 PM
  #11519
bilster44's Avatar
Hell's yeah I'm running them! I posted a couple of pic's back on page 14 of this thread.
Old 02-16-2012 | 03:46 PM
  #11520
Does anyone know what set up steve hartson was running at smak track
blingy is offline
