HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree16Likes
Old 08-27-2011, 08:20 PM
  #6211
ngnaw's Avatar
I'm happy with the 4S runtimes and speed for now. Shopping around for 6S, and unlike the 4S where it's cheaper to actually get two 2S lipos, I was wondering what lipos are people using for 6S? I have options of 30C or 40C discharge with 5000mah... anybody have problems running 6S? Does the 6S lipo fit in the battery tray? I'm not the type to floor the car, I think I have a good understanding of throttle control. I floor it when needed and would like to have that power available when wanted. What are your opinions and recommendations... This is purley for urban bashing this 6S...
ngnaw is offline
Old 08-28-2011, 01:22 PM
  #6212
paba60's Avatar
Trader Rating: 34 (100%+)
Hey Guys....just picked up a Vorza on trade...
Was really fun for 5 minutes until the Left Front CVD popped out of the drive cup. ;(
Take a peek at the pic... Is the dogbone that close to the end of the drivecup on your vorza when the suspension is in full extension?
paba60 is offline
Old 08-29-2011, 07:33 AM
  #6213
Hi guys,thinking of buying one of the new vorza,s when they are available,but unsure which battery setup is the best,also can you run on just one lipo battery instead of fitting two in the car?....thanks....
jon9e is offline
Old 08-29-2011, 07:53 AM
  #6214
jones8352's Avatar
Originally Posted by Azagar
Yes I had the exact same problem and currently using the Racers Edge capacitor but I have a CC bec coming soon. It's not really all the mm esc fault but savox receivers in general .
Thanks Azagar, I installed the same capacitor and the problem went away. For $4.99 a quick inexpensive solution that works great so far.
jones8352 is offline
Old 08-29-2011, 08:00 AM
  #6215
jones8352's Avatar
You can run a single battery if you want. I run Gen Ace 4s 40c 5000mah packs, they work great. Just take a short piece of wire, solder it to both sides of a connector and plug it in to the neg side of the esc to complete the circut.
Old 08-30-2011, 06:57 PM
  #6216
TimMo846's Avatar
+1 You can run a single battery as long as it's 4s and 25+c rating. Minimum requirement for the car.
TimMo846 is offline
Old 08-30-2011, 07:03 PM
  #6217
ngnaw's Avatar
I am now going all lipos 40C... Nothing less...
ngnaw is offline
Old 08-30-2011, 07:36 PM
  #6218
TimMo846's Avatar
why's this? Found out the power difference?
TimMo846 is offline
Old 08-31-2011, 12:48 AM
  #6219
Suspended
Trader Rating: 132 (100%+)
Ran the Vorza for the first time tonight...Handled a little better than my old one, but the Kyosho spur...Wow! My Vorza was soooo quiet! Thanks to Z4Kevo again, his help and generosity got me up and running, and gave me enough spares for a looong time lol.
badaml is offline
Old 08-31-2011, 04:37 AM
  #6220
ngnaw's Avatar
Discharging a lipo capable of this 40C rating would cause less stress and no puffing of the lipo. Whereas with 25C or 30C you are close to the max amp draw of the motor and esc. On my other RC I used 20C and the lipo got really hot and puffy cause the motor and esc were overdrawing amps... Even though people were saying 20C was fine... Plus lipos will last longer if not stressed out.
ngnaw is offline
Old 08-31-2011, 12:57 PM
  #6221
Your ESC won't be drawing more amps from 25C batts than from 40C batts, on the contrary, since the 25C battery voltage will sag more under load. You'll get more grunt with higher C batts, but may not be really noticable since the wheels will spin easily even with lower C batts.
25C batts will be harder on the ESC capacitors though (higher ripple).
I'm using 5S 5000mAh 45C Zippy pack from HK and it's a perfect fit.
suresnoi is offline
Old 08-31-2011, 01:47 PM
  #6222
PorTX's Avatar
"Back in the saddle again"..... But watch the Z4Kevo guy....
PorTX is offline
Old 08-31-2011, 03:10 PM
  #6223
ngnaw's Avatar
I'm just comparing the 40C to anything lower. I see the difference with the lipo being cooler, no puffing over the long run etc etc. It's just better overall than what they recommend...
ngnaw is offline
Old 08-31-2011, 04:34 PM
  #6224
Z4Kevo's Avatar
My pleasure Badaml! So you had a good night of practice/racing?
Z4Kevo is offline
Old 08-31-2011, 04:36 PM
  #6225
Z4Kevo's Avatar
Haha! Good to have him back! More competition!
Z4Kevo is offline
