HPI Vorza Flux 1/8 E-Buggy Thread
#6241
Thinkin of the novak 5626 glitch buster to go in my vorza with a savox 1256 servo.do you think this would be ok?.....thanks.
#6242
Hey guys,
My Vorza goes straight when rolling gently but goes to one side under strong acceleration. How do you call this behavior ? And what causes it ?
Other than that, it's running really great.
BTW I have changed the rear shock setup :
- oil from the stock 45 to 50wt
- swapped the stock 60mm rear spings (orange) with 68mm Red (81Gf) springs.
- most vertical shock position (outer hole on the tower, inner hole in the triangle)
29mm riding height.
The result seems improved but the chassis will still hit the ground on jumps, even not huge ones.
I wonder if I should go further and use 60wt and/or go with the 1.2mm holes pistons. I would like to make it work without dropping $$$ on the 112 shocks + shock tower.
29mm riding height.
#6243
Hey guys,
29mm riding height.
29mm riding height.
#6244
HPI ofcourse really loves to sell those rear shock upgrades they make good money on those i guess..
I also have it, but there are other things you can do like just putting larger ball ends on the shocks
Or maybe just get the 112mm shock shafts, im not sure this maybe could help also
Maybe these help for the suspension: http://rcshox.com/shoxshop/catalog/p...products_id=39
I really dont know
I really dont know
#6245
Hey guys,
29mm riding height.
29mm riding height.
#6246
HPI Vorza LEDs and EC5 Connectors
Here are pics of my Vorza! I added LEDs and EC5 Connectors!
#6247
Thanks azagar,think i will just get one and hope it works.......
Is it better to run one 4s lipo or two 2s 7.4v or 11.1v lipos.What do you guys run?....
#6251
For 4S I go 2x2S and for 6S I went with 1x6S since it was cheaper this method... Also 40C I won't go anything lower and 5000 mah minimum depending on size of lipo. I get around 50+ minutes on the 4S
#6252
I was thinking of getting two of these,Orion Carbon FLX 6000 45C 11.1V (Deans) £99.99
What do you think?
What do you think?
#6253
Best regards
Nicolaj
#6254
#6255
I would have to agree that does seem like a lot of money, granted they are considered some of the best lipos by most.
This is what I use, found some bullet connectors designed for 90degree placement on a battery pack at my LHS which are perfect for the vorza. Wire length is just to my correct length to not create any extra slack underneath the body. When I need to charge, I just use the typical connector with the balance tap.
