HPI Vorza Flux 1/8 E-Buggy Thread
#5465
I put a 44t Kyosho spur in mine without and modification. I ran it with a 19t pinion for several months without any problems. They're much wider than the stock steel spurs and even after two months looked real good. I finally stripped it during a race but it was my fault for not checking the motor mount screws.
Jerry
Jerry
#5466
Jerry
Jerry
#5470
Jerry
Jerry
And secondly, any1 has any idea if the D8 Hi Flow body from Jconcepts work for the Vorza??
#5471
Which motor?
I ordered a Tekno chassis kit and it should be here today or tomorrow at the latest. I think I have enough parts to put it together and still have a running Vorza. The problem is which motor to put in the Tekno kit. It's going to be strictly for racing. I have three motors that would work, A Castle 1800, 2650 and of course the 2200 that's in the Vorza. I think the 2200 has a bit more power than I really need for racing. The 2650 on 4s runs a tad on the warm side. I think it would be better on 3s. The 1800 has a nice smooth power band and runs cool enough in 4s. So which one would YOU use? The track I race on is big, it's 120'x100'. Long straight and big jumps that don't have much run up room.
Thanks for the imput!
Jerry
Jerry
#5472
Jerry
Jerry
#5473
Jerry
Jerry
#5475
Hi Jerry! thanks for the input.. but 1 thing to clarify.. the meshing of the plastic spur should not have as much free play as the normal metal spur? or is it similar free play as well? i run it a little loose.. when i use my 17T pinon, i shift the motor mount the the most outside position..
Jerry
