Tekin RX8 1/8 Scale Brushless ESC Thread
#2912
I run the 2050 in my RC8 with 44/16 gearing for a medium/large track. I don't think you will have a problem gearing the 1900 for use on 4S on a smaller track. Kit stock I believe is a 46 spur and I don't know what the pinion is. Start around 15 or 16 and work your way from there. To be geared for the same speed as my car you would have to run an 18 pinion. I am geared fairly slowly for a 4S setup, only around 36 mph.
#2913
IT WAS THE BATTERY!
Randy
Its Jake I was the one who asked what was wrong when you get no chime or lights...
Well it turned out it was not the ESC it was the battery thats why it was not arching.
New batt and no standing voltage in process of checking batt for a open. So glad it was not the ESC.
I wanna get running but cant afford another 5000 5s. So would a 4s work ok with a truggy 5500 motor. If yes whats the gearing? I mostly run at SRS and the Nitro pit in Phoenix AZ.
Thanks in advance
Jake
Thanks in advance
Jake
#2914
Randy
Thanks in advance
Jake
Thanks in advance
Jake
#2915
Randy
Thanks in advance
Jake
Thanks in advance
Jake
#2917
Jake, I hope you don't have a 5500 motor?!
If you meant 2050 try 46/15 in the Losi. If you meant 2000 it's about the same. If you're going to 2250 try a 14.
#2920
#2922
I'm running the 1900 combo in an RC8E with 2 (2s) TP5000 packs geared at 46/14 (I just went up to a 16t but haven't run it yet) We ran a 12 minute main on a large track and I put 2830 back into each pack. Hopefully I'll get to try the 16t on Saturday and have a better understanding of how much runtime to expect.
#2923
OK, that's more like it.
1550 in the buggy on 4s I'd be looking pretty big like say 43/18 to start out. Low timing at first and see how it feels on 4s with that gearing. If it's feels pretty good but is lacking some snap and top end bring up your timing to 20-25 and go out again.
I haven't tried that combo yet...I bet it's wicked driveable and fast lap times because of it!
#2924
#2925
Randy I send you an email about the case of rs pro and rotor of T8.
Thank you
Thank you
