Tekin RX8 1/8 Scale Brushless ESC Thread >
Like Tree3Likes
Old 06-25-2019, 01:06 PM
  #18841
Krio's Avatar
Trader Rating: 159 (99%+)
Originally Posted by TopGearRC View Post
Hello Randy,
I have a RX8 (https://www.teamtekin.com/manuals/tws_manual_rx8.pdf) this unit has never been used until now, it was sitting in my parts box for a few years. I’m unable to change throttle profile or anything in the I have done a factory reset on it but it would still not go in the quick tune mode. When I press the mode button I do not see any LED’s (as it should) If I press the mode button 5 or more times it goes in celebrate mode. At startup, the unit boots up with the correct number of chimes, then connects with my TX properly.
Please let me know if there is anything I should try.
I sent you an email last week about this issue but haven't received any reply yet.
Do you have a hotwire adapter? I would suggest a fresh firmware installation as a way to eliminate old software as a possibility.
Krio is offline
Old 06-25-2019, 01:07 PM
  #18842
Krio's Avatar
If all you need is to switch the motor direction, you can switch any two wires connected to the motor. Shouldn't take more than 10 minutes.
This works only if you aren't using a sensor cable. If you want the sensors to be used for startup and low rpm, reversing the rotation needs to be done in hotwire.
Krio is offline
Old 06-25-2019, 02:14 PM
  #18843
Trader Rating: 21 (100%+)
I don't have the hotwire adapter. I figured out the issue, my motor was running backwards. Switching direction on the radio did not have the same effect, so I switched the wires at the motor terminals to reverse its direction. I was able to get in the quick tune mode once I disconnected the sensor cable. Is it absolutely necessary to drive with the sensor cable attached? What performance compromises would I see (if any) ?
TopGearRC is offline
Old 06-26-2019, 05:02 AM
  #18844
Krio's Avatar
Starting from a dead stop is a bit smoother with the sensor cable and the brakes can also be more consistent. It's a fairly small difference, but if you want the absolute best performance you'll want the sensor cable.
What car is this in? Can you flip the differentials to change the tire direction?
Krio is offline
Old 06-26-2019, 01:11 PM
  #18845
Its in e converted - Team Associated RC8 Buggy 2.0
Old 07-11-2020, 04:04 PM
  #18846
Default Rx8 help
I run a rx8 gen 2 in my drag car and after I turn it on it shuts off and turns on by itself, I hooked it to my computer and reset everything.
Also my reciever doesnt lose power just the esc goes off and on by itself
ur2slw is offline
Old 07-14-2020, 10:51 AM
  #18847
Team Tekin
Tekin Prez's Avatar
If this is happening on the bench we need to see the leds while it happens. What the leds are doing specifically tells us a lot to help with diagnosis.
Tekin Prez is offline
Old 07-14-2020, 12:50 PM
  #18848
Trader Rating: 19 (100%+)
If you want to run the RX8 with a sensored motor terminated to run in reverse you will need the hotwire to reverse the sensors to be able to use the sensored mode in reverse phase.
Juglenaut is offline
Old 07-14-2020, 12:56 PM
  #18849
I am not 100% sure, it has been a little while since owning a AE. However it looks like the differentials can be put in the other direction.
I sourced a copy of the manual of a rc8b #80902
Old 07-14-2020, 12:58 PM
  #18850
Old 07-14-2020, 01:11 PM
  #18851
Old 05-18-2021, 09:51 AM
  #18852
madweazl's Avatar
This past weekend I was having problems losing power to my speed control. It happened with 4 different battery packs so isn't likely to be a battery issue. I use 5mm bullet connections (very tight in the batteries) direct to the battery and all solder joints are good. It has worked flawlessly the two seasons prior to this. I lose steering and throttle. Motor temps are 140-145 and the ESC runs 103-108. Tested it out again yesterday (no other vehicles on track) and when it shut down, it made the beeps like it does when you first power it up (think it did that twice back to back but I'm not positive). No lights on the ESC to provide a fault code (I can't recall if the fan was still spinning or not). Turning it off/on restores power and everything works as normal again.
Gen 3 RX8
Gen 3 1900kv
madweazl is offline
