Tekin RX8 1/8 Scale Brushless ESC Thread
#3061
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I'm going to disagree with you there. My Robinson 12T hardened steel pinion is showing wear after a little over a year running with a Kyosho plastic spur (the same spur). All I can think of is that the grit in our dirt gets embedded in the plastic and gradually sands down the pinion.
It's not like it is worn out - I've probably got another year on it, but the wear is visible without needing a magnifying glass.
#3063
Hi Team Tekin,
I was running my losi 8T yesterday and the motor seemed like it died on me. I have the 1700KV truggy motor. basically, the motor will stop but the ESC seems to be working. then all of a sudden, the motor seems to be fine. then it will stop again, then go. I checked all the wiring and everything looks good.
also, with my losi buggy, i also had some stop and go's. but for the buggy it seems like it was the entire system shut down so I am thinking it is the ESC. I also checked all the wirings and every looks good.
please note my entire system besides the ESC in truggy are most likely 1st generation systems. i have also send email to support@tekin.
Please send me email at [email protected]
Thanks and awesome product!!!
#3066
Hi Team Tekin,
What type of radio are you using? I had something similar to this when my BEC failed. The receiver would loose power for an instant and it would proceed to reboot (find the transmitter and all). This did take a couple seconds to happen. I use the Futaba FASST system. Does your steering work when this happens?
#3067
#3068
I am very happy with them so far. the system is great and even thought they have some problems I believe there still better than anything out there.
I have a really big race coming up so I just ordered another combo. Got a 1700kv Truggy system this time. So now I will have a backup if anything fails on me.
Guess I will have to build a buggy now. DARN
#3069
#3074
Holy replies
![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
#3075
Guest
Hi, are there some people who have the HOTWIRE ?
I would like to customize the LVC with the HOTWIRE, but I can only set up the value of one Lipo cell. I use 2 x 2S Lipos and want to set up my LVC around 12,8V !
How can I do ?
How can I do ?
